ArduCopter 2.7.2/2.7.3 released
Arducopter 2.7.2 is now in the mission planner and in the downloads area Some positive reports on testing can be found in this discusssion by John Hanson.
Note: just as the release was going out an issue was found re support for the all Camera Gimbals on the APM1s (it doesn't work) and with 3 axis gimbals on the APM2 (2-axis works ok but not 3).  If you're one of these people, please wait for 2.7.3 which will be out shortly.
UPDATE: 2.7.3 is now in the Mission Planner
Functional Improvements over 2.7.1:
  • Fast waypoints (Jason) - if the turn angle between two waypoint the copter is less than 60 degrees it does not slow down
  • Navigation improvements and logging including switching to filtered location for distance calculations (jason)
  • Flip improvements - more aggressive and flexible flip code based on attitude instead of timing (Jason)
  • Improved camera control - you can now control any axis (roll, tilt, pan) with any rc channel.  it probably makes most sense that you will use 6 but others are possible too.  Unfortunately these changes required we change the set-up procedure so the mission planner gimbal set-up screen needs to be modified again.  Please refer to the AC_Camera wiki page for how to manually set-up the gimbal (Amilcar)
  • Flybar acro mode for TradHeli (Robert)
  • "Fast gains" - allows strong correction of attitude using accelerometers while the quad is stationary on the ground but relies more on gyros while flying (Tridge, Jason)
  • Baro filtering improvements (Tridge)
Bug Fixes:
  • DMP timing fix (Randy) - the MPU6000's dmp unit was inadvertantly turned on and caused timing delays in the main loop- xbee bricking issue (Craig / Tridge)
  • Dataflash fixes (Jason)
  • Engine ticking - was a combination of roll/pitch rate D term being too high and the dmp timing fix above (Randy, Emile)
  • Faster heading correction on start-up - resolves issue with simple mode getting incorrect heading if you took off very soon after start-up (Tridge)
Code Cleanup:
  • Increased maximum number parameters (Tridge)
  • Formatting changes to code (Pat)
  • Replaced "int" with "int16_t" everywhere (Randy)
As per usual PIDs are optimised for the 3DR/Jdrones quad with 850 motors and 10" props. If you're using more powerful motors/props and are seeing bad flight behaviour in stabilize, start by turning down Rate Roll P in 25% steps.
There is still some question on whether the default Roll/Pitch Rate P (0.175) is high enough (it was 0.185 in 2.7.1) and also some people feel the Throttle Rate should be higher (currently 0.300 but some say 0.330 or even much higher would be better).
Please feel free to report issues you find in the discussion below and/or add them to the issues list.
Thanks and enjoy!
  • Mission planner says "ARMED" but if i up throttle, motors won't start. 2.7.3fw
    Why?
    How to resolve?
  • Calm day at last, flew all modes, perfect! Auto was the best, most accurate to date!
    Slight vertical springiness in alt_hold (baro only). About 0.3 ~ 0.5m rhythmic up/down, any idea what para to tweak?
    Peter
    If you are using a Xbee you should set TELEM_DELAY to a value of 3 or larger. The default now is to not delay telemetry. A TELEM_DELAY value of 3 will delay telemetry for 3 seconds, which should stop Xbee bricking.
    Cheers, Tridge
    Yeah as far as I can see here at jDrones too, this is one of the best behaving release. It is getting really nice to fly. I really like it's yaw now and yaw speed.
    As randy said it work really well with default setting with all jDrones and 3DR frames. It's been a long run but we are getting there.
    I really suggest everyone to try it and give more feedback to us all.
    jDrones, R/C UAVs and More....
    Manufacturer of ArduCopter frames and parts. Custom airframe manufacturing, Custom design services for all your R/C UAV needs
  • Basic functionality in Stabilize mode tested GREAT! More testing tomorrow. Great job.
  • Nice work guys! I have only tested stabilize on my quad......the stock pids flew great !!
  • Really happy with the basics in 2.7.3! Feel confident enough to start pushing some of the more advanced functionality now!
    Great work!
  • Today I've tested my DIY octo, with only 4 arms for now (i have to add 4 more), was the first time this machine is in the air and with standard PID AC 2.7.2, it has flown awesome. It's a big frame, 900mm diameter, and big powerfull motors leopard 3542 920kv 2200gr pull force, 4s battery and 12x45 carbon fiber propellers. ESC's 40A with simonk's firmware.
    Thanks a lot to developers!!
  • I was able to get the gamble to work on 2.7, 2.7.1, and 2.7.3 however in 2.7.3 it is moving in full up full down it is not proportional. It works the same on stable. The copter tilts forwards it doesn't move for a bit then once it tilts forward to a point it then goes full down. I might be doing something wrong but I have the settings the same as 2.7.1.
    I'm happy to read many positive reports, thanks to all and enjoy!
