ACRO bug (fixed in 2.9.1b): while doing flips in ACRO mode, if you switch to Stabilize while inverted your throttle will go to minimum. To regain throttle control you need to switch back to ACRO then back to Stabilize again (i.e. switch to stabilize twice). You never lose control of roll/pitch/yaw.
Loiter/AltHold/Auto/RTL bug: if you switch into these modes with throttle at zero motors will go to minimum until you raise the throttle.
Auto mode altitude bug (fixed in 2.9.1b): setting a waypoint altitude greater than 320m over home altitude may wrap around and instead be interpreted as a low altitude.
ArduCopter 2.9 is now in the mission planner and the downloads area!
The major improvement is we use inertial navigation to improve altitude hold. This increased reliance on the accelerometers means you must do some additional set-up before flying:
1. Perform the new accelerometer calibration in the mission planner (video). The auto-trim metho has also changed (video).
2. Add vibration dampening foam between your frame and the APM. Some suggested materials: DuBro, gel, hk foam.
3. If upgrading from 2.8.1, modify the throttle and altitude PID values:
- Increase your Throttle Rate P, reduce I to zero, increase D
- Increase Altitude Hold P, reduce I to zero
- Tune Throttle Accel P and I terms but try to keep P about 1/2 the size of I
Here is the list of major changes (a more detailed list can be found in the release notes):
- Alt hold using inertial navigation (Leonard, Randy, Jonathan)
- AUTO_VELZ_MIN, AUTO_VELZ_MAX parameters control the max climb/descent rate for the autopilot (cm/s)
- PILOT_VELZ_MAX controls max climb/descent rate for the pilot (in cm/s)
- Landing improvements (Leonard/Randy). Copter will descend to 10m or until an object is sensed with the sonar. Then slows to 50cm/s descent (speed can be adjusted with LAND_SPEED parameter). (video).
- Surface tracking with sonar (Randy/Leonard). Copter will attempt to maintain current distance from objects in front of sonar regardless of altitude. Only used in alt-hold and loiter, not used for missions. Sonar can be enabled/disabled with CH7 switch. (video)
- Failsafe improvements (Randy/Craig/John Arne Birkeland) including bug fixes, additional check for PPM encoder failure and implementation of battery failsafe. Set-up instructions are here.
- Mediatek gps driver accuracy improvements and use of SBAS [Craig]. Instructions on upgrading your mediatek to firmware 1.9 are here.
- Traditional Heli improvements (Rob) including (a) bringing heli code back into the fold, (b) enabled rate controller (previously only used angle controllers). (c) fix to rotor speed controllers - now operates by switching off channel 8. (d) allow wider collective pitch range in acro and alt hold modes vs stabilize mode (e) bug fix to allow collective pitch to use the entire range of servos
- Acro trainer (Leonard). Copter will return to be generally upright if you release the sticks in acro mode.
- ACRO_TRAINER : set to 1 to enable the auto-bring-upright feature
- ACRO_BAL_ROLL, ACRO_BAL_PITCH : controls rate at which roll returns to level
- Camera control improvements (Randy/Sandro Benigno): (a) AP_Relay enabled for APM2 (b) Trigger camera with CH7 or DO_DIGICAM_CONTROL command (c) Allow pilot override of yaw during missions and fixed CONDITIONAL_YAW command.
- PPM sum support for transmitters with as few as 5 channels (Randy/Tridge/John Arne Birkeland).
- Performance and memory useage improvements (Tridge).
As per usual PIDs are optimised for the 3DR/jDrones quad with 850 motors and 10" props. If you're using more powerful motors/props and are seeing bad flight behaviour in stabilize, start by turning down Rate Roll P in 25% steps.
Special thanks to our testing team lead Marco and the dedicated bunch on the 2.8.1 release thread who put their copters at risk while testing the pre-release version. Some of their videos are here: 1 2 3 4 5 6 7 8
Please feel free to report issues you find in the discussion below and/or add them to the issues list.
I just set up my big quad with 2.9.1b and when I did the live compass calibration I get a completely different reading to my small test crash quad. On my small one I had "New offsets are -113-45 191" and on my big quad I just now got "91 -64 297". Yet both were in exactly the same spot on my balcony and both had 5 to 6 sats reading. Any ideas?
While thinking of failsafe options on my own project, i found something easy to prevent a complete flyaway. Some radios can not setup a FS in their RX (cheap), or the user is too crazy not to do it, and the RX just keeps sending the last valid RC Data instead of disconnecting or sending lowest throttle. In that case i implemented a 3rd stage of fs (1st RX, 2nd FC detects missing RC data). It is just a timeout, if thr/yaw/nick/roll (just a checksum) don't change for x seconds (30+ seconds?) i do a "Deadpilot" Failsafe (RTL,Autoland). This Deadpilot FS must be excluded from automatic tasks like Automission, Autolanding etc.
Perhaps it's an idea.
Cheers Kraut Rob
As some have noticed 2.9.1b is now in the mission planner and in the downloads area. I had to call it 2.9.1b-final because I basically called the release candidate 2.9.1b. In any case, the improvements over 2.9.1:
I read in post somewhere not long ago about 'copter control in Loiter changing in 2.9.2. Instead of the 5 metre push & shove zone it'll respond fluently to stick input.
My suggestion is to allow a small stick dead-zone to allow for slight out of trim states of the copters. My thinking is that any small trim input may/will cause a fly away. Reading stick input at the time of changing into Loiter mode may not be successful either if you are manually holding position (due to wind).
This may have already been considered, but this post hasn't cost me much in ink.
ohoooo..2.9.1.1b is in the house..i meant in mission Planer
What are the main differences between v2.9.1 and v2.9.1b now in the MP?
Hi Guys,
This might be a little off topic, but I thought I post it anyway.
After changing motors on my F450 to T-Motor 2216 I finally have the copter sorted when it comes to vibration.
Camping on the farm the past Easter weekend provided the perfect opportunity to try an "auto mission".
After some smaller successful missions we tried a almost 2 KM flight over the "Hohenfels" mountain right next to the campsite.
Mission is +- 1.9KM long and flown at a altitude of 200m above ground level to avoid a crash into the mountain that is +- 50m lower. Nr. of way points totals 9 with a decent in two stages on the return leg. One to 150m and the second to 30m.
My Setup is:
F450 Hobbyking clone.
APM 2.5 with 2.91 firmware.
18A Tower pro ESC's.
T-Motor 2216 800kv.
APC 10X3.8 props.
433mhz telemetry.
3300mah 3 cell battery with the Go Pro just temporarily stuck on with double sided tape.
The "mission starts at +-16 seconds in and ends at 6.30 when reaching the loiter altitude.
Hope you enjoy.
https://vimeo.com/63302808
I'm just hoping someone can verify my X Y vibrations are satisfactory? The first spike in the graph early on is a landing with a pause before taking off again, the last is obviously a landing.
My Filter is currently set at 20. Should I, could I or do I need to move this value?
I'm using a very simply & low hassle vibration absorption system I thought up. If my results are OK I'll post a description & photo.
Thanks in advance.
PS: I've tried the foam & O-ring methods :-(
OK - that was ugly. Was in a hover with throttle at 50%. Flipped into Alt-Hold and the quad shot straight up at very high speed. In the past I saw gradual climb from Z vibration (not on this quad), but this was extremely fast and ended up being destructive as it hit a tree and came down hard. 2 broken motor mounts, two broken props, a cracked mounting board, and a smashed dome. Luckily the GoPro landed on soft turf. Trying to get a log off of it now. Is is possible for vibes to cause such an extreme reaction? Maybe something came loose and started things shaking too much?
I haven't been flying Arducopter for several weeks, and yesterday I tried 2.9.1 with my new APM2.5 and U-blox NEO-6M GPS module.
U-blox GPS is more precise than the Mediatek one, I tried Loiter in constant wind (30 km/h), and my copter was very stable, first time I notice this, before with APM2.0 and Mediatek, it was circling around maybe within a 10m diameter.
Now with U-blox it's like is not moving anymore (same parameters between APM2.0 and APM2.5).
I tried also to move my copter in Loiter mode, and when it was moving forward, it start climbing very high, I don't know if it's a known problem.
I also notice, when I enter in "Alt Hold", motor stop spinning for a short time, it was very scary, so I remember that I shouldn't climb when entering in "Alt Hold", I tried a second time when I was almost level, and same thing happen.
1
2
3
4
5
of 26 Next
