ArduCopter-3.0.1 released!
Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
3691038784?profile=original
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to Marco, DaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found here, here, here, here, here and here.  Thanks also to MichaelO for the MP changes required for this release.
  • Just a quick note to the Devs.
    I had some issues with a faulty motor on my Y6, but its sorted now, and with the correct parameter file applied, managed to get some good stick time yesterday.
    AC3 flies like nothing before it, I have never had such a locked-in feel on a multicopter before.Alt Hold is Rock solid, Loiter is nailed to the sky, RTL works to within a 3 foot radius, the weekend I hope to do a few Auto missions.
    Well done Guys! When you read the forum posts one sometimes dont get just how grateful the community are for your hard efforts and long hours.
    Let me assure you, we are like this :
    3692819802?profile=original
  • T3
    @Tvixen
    You can create your own default list. First save your parameter list (look under Advanced Parameter screen), then erase and reset your APM and then load firmware. Now goto advance parameter again and do a compare and load your saved parameter. I always use these steps with new firmware to compare changes.
  • Hi Randy
    I have a small problem , I wanted to set a new firmware on a new AMP2.5 Board .. So I did connect it to MP unmounted to frame and with no wires attached just the bare board with USB to laptop ..connected to laptop fine and booted up ..then I went to CLI ..and did a RESET ..it asked to confirm with a Y ..and I did confirm to reset ..then it asked to reboot the board ..So I unplugged it and plugged it in back in to reboot .. That's when my trouble started, it is now not being picked up by the laptop and MP does not "see" it .. After boot it has green power light on and Red led blinks slowly .. What have I done wrong and how can I get the MP and laptop to Recognize the board ?  Have I bricked it? Do I need to re-flash a boot-loader to the ATMega chip ??
    Regards Reuben
  • Hi Guys ..
    Would it be possible in future firmware to have the compass calibration done like Dji ?  Flicking the mode switch rapidly for more than seven times activates Compass calibration and LED light changes colour indication its in calibration mode ..then for each axis different color light ? Its not too user friendly at the moment when you have different sites/countries to visit and fly.
  • I have also nice words about AC3.0.1. Very very good review.
    I have a good loiter, stab, alt-hold, rtl (small problem) and land.
    All this, only after very well isolate imu, insulators from an old CD player, and add weight with tiny lead balls at the base of the box imu. Also and very importantly, raise the MAG and GPS over the electronics with a long spacer.
    I use only the signal wire from receiver to IMU to avoid vibrations spreading. (also from imu to escs)
    I had a problem with the orientation of the external mag, which is already fixed (beware with silked arrows).
    Thanks to the developers. Very good job.
    The RTL issue is when I change from stable to RTL through loiter with a 3 position switch (stable->loiter->RTL). In this situation the motors stops a fraction of a second.
    The yaw also are not good enough for me, but I think is a tuning issue.
    Loiter and Land are awesome. (supersimple also)
    3692818303?profile=original
  • Are there any Beta versions after 3.0.1? I don't see any beta versions on the Mission Planner.
  • Hi Guys,
    Just wanted to take a minute to say a big thank you to the dev team. You guys are unbelievable with what you keep achieving!
    I have built a larger quad-octo for survey work and I am using turnigy multistar 40amp speedies. I had it tuned close to where I thought it should be, but just couldn't get that final bit, that locked in type feeling.....until yesterday!
    I was changing the power distribution system, cleaning it up a little, when I thought I would look to see if these speedies are compatible with the simonk firmware,... After I found which firmware to load I updated all speedies and oh boy what a difference!
    My P and D terms went from around 2/3's default (P 0.09~) to around 0.22. I am running a higher D term as well. almost everything else is default values although I did play with alt hold settings a little.....
    I was quite surprised to say the least as being a much bigger system and hovering around 35% throttle I thought I would have a lot more tuning to do.
    SO what have I learnt from this???   APM just works! There are no shortcuts, and if you follow the setup guides by Randy and others ( brilliant job there btw guys!) then it should just work. If it doesn't work then it MOST LIKELY is NOT the fault of the APM but just not setup correctly.
    If you need to disable compassmot then something is wrong and needs to be addressed.
    If you need to disable any of the startup checks to make it work, then please don't use the autopilot side of things and DON'T rely on RTL, as it can't be guarenteed to work as the copter is not setup corectly!
    I have done many auto missions with a big octo full auto take off to landing and only use the tx to arm and initiate the takeoff. close on 80 flights now with no surprises.
    In a nut shell if it isn't working for you then YOU must realise that you have some work to do, please keep this in mind when asking for help. Everyone here is here because they love it and are willing to help, so keep calm, understand that it is not working because of something you have done or not done and let us help you!
    Once again, hats off to the dev team!
    Best Regards
    Steve K
    3692818028?profile=original
  • Just wanted to add a positive review of the upgrade. 3DR Hex here with everything loaded like a Cadillac! Anyhow I put off upgrading because I thought 2.9.1 was flying good but I finally upgraded and its much much improved. When I switch to Loiter its smooth I mean the thing just holds no fluctuations unless I come in hot and hit the switch but it will settle fast. I had a little problem with RTL but my setup RTL_ALT was set at something like 3000 I set it to zero. It would go into RTL but then gain alt because it was wanting to go to the 3000 programed in then start dropping ALT. I tried it out 2 times and walla no issues lands very nice. I only use RTL for emergency landing otherwise I feel you as the pilot should be landing in stabilize mode to keep up your skills its just like flying a real plane 3 takes offs and 3 landings to stay current.    Anyhow I can't comment on the Auto Pilot stuff because I don't use that this is an A/P machine.  I will do more Autonomous stuff with another machine or the fixed wing I am building for agriculture mapping.
    So Again Kudos to the team and I look forward to many years of updates. I just saw the 3DR Pixhawk I
    I wish I would of went with the PX4 to start but that's how it goes I think next run will be PX4 / Pixhawk based, the processor is much faster for future updates and such as I see it. But the AMP 2.5 is staying on this hex.
  • I do not see the same tabs as you see and trying to update from the help tab where I think I need to go now it fails :(
    3692815460?profile=original
  • I upgraded to 3.0.1 and haven't had any problems.
