ArduCopter-3.0.1 released!
Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
3691038784?profile=original
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to Marco, DaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found here, here, here, here, here and here.  Thanks also to MichaelO for the MP changes required for this release.
  • Man this is getting deep and frustrating to find my own posts! And the lack of a topic search is, well, why?  Can we branch off into and RC5/v3.1 version of this?  Just curious.
  • Well I just ordered a new 3DR APM 2.6. Hopefully this will work for me.  Oh - also pulled the trigger on an Iris!
  • You can use a 6 channel RC Txm for Autotune.
    Just plug 6th channel from RC receiver to APM's 7th pin input signal pin.
  •  Just finish running autotune and I'd like to report that it works perfect for my quad! I think v3.1 now ready for it's official release.
    Thanks to Randy, Leonard & members of Devteam!
  • spent the day testing RC5 and found that the Minim OSD no longer displays the flight mode. (I think its missing from the MAV)  No other hardware or software changes were made to the Hex other than loading 3.1 RC5.  didn't notice any other problems (REALLY liked auto tune)
    Firmware replaced was 3.0.1 ( I have not loaded or tested any other RC's, so I don't know if its a new bug or has been here a while)
     Steve
    Steve
  • Here is a TLOG of a failed auto tune. I've tried it many times but it always fails after about 30-40 roll iterations. Does it show in the log why it failed? I have the onboard log as well if it's needed. APM2.6 standard gps. rc5. 10" props.
    2013-10-27 14-13-25.tlog
  • I've got one particular APM board which climbs aggressively when I move forwards in alt hold, and drops (quickly) when I move backwards. I suspect it's somehow a faulty board, but can't interpret the logs well enough to be sure.
    I have the info/dataflash log here: http://diydrones.com/forum/topics/climb-drop-when-moving-forwards-b...
  • Leonardo, I just tried to do an auto tune with a overpowered octo and had to abort it after about 45 seconds or so it seemed. It must have done 30-40 iterations on the roll with some more aggressive than others. I had to catch it 2 or 3 times from getting too far away. At one point it jerked so hard to the right that I decided to flip switch 7 and abort. Is there a way to calm down the auto tuning? I can video it tomorrow if anyone wants to see. I can upload the logs too.
  • After completing an hexacopter  and testing , it has a random defect, it twitches always in the same direction very short duration.
    I suspects of   some kind of power issue, probably power module is not able to keep voltage steady ,
    I appreaciate if somebody with more experience could take a look at the readings and help my understand what may be wrong.
    2013-10-26 11-06 3.log
    https://storage.ning.com/topology/rest/1.0/file/get/3692866094?profile=original
  • I just did my first auto tune with my smaller quad and it went great. Need to do it again in less winds but wanted to check it out. When I landed I don't know if I did something wrong but the values were the same. It did it's dance and then I landed and disarmed. Then came to my MP and clicked Refresh but nothing changed. Is this perhaps because I have ch6 tuning set to Stab Roll/Pitch kP? Also is there any info on what parameters it tunes? Just stabP or Rates also? What about Throttle Accel?
