ArduCopter-3.0.1 released!
Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
3691038784?profile=original
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to MarcoDaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
  • Working with RC7 on my new F450 Flame wheel that i transferred parts from the Walkera X350 i am wondering how to set up my throttle mid. During testing outside, i can hover at about 42-45% throttle, when i hit Alt Hold/Loiter, the aircraft gains altitude as if the APM thinks i should need more power to hover. looking at my log verifies the THR_MID at 450. what am i missing here?
    Also in doors, i seem to be having a problem or hitting up against a fail safe. my props are off (I learned my Lesson last time) i am testing the THR_MID settings and my F450 just turned on while the TX Was on but HDOP was between 2.5-3.96. what failsafe do i need to turn off while in doors messing with parameters? What Failsafe would trigger if i am indoors? if it helps any, a couple of tests going into  ALT HOLD/Loiter from STABILIZE, the Motors revved down then shut off. i figure thsi must be some how related to GPS Loss of some kind.
    Log Attached is from todays Short FLight OutSIDE, not in doors
    thanks in advance
    2013-12-03 18-35 17.log
  • Would anyone have a screenshot from a log of a well tuned Alt-Hold? I've been tuning off and on for a week and it will look good in the field but once I look at the logs it seems to fluctuate quite a bit. I wonder if im chasing my tail trying to get the baro and RelAlt to be in sync. Thanks in advance.
  • Hello!
    I have a problem with my new hexa.
    I upload a video to youtube. In this video you can watch the wrong performance of motor without any stick movement. Please, watch in HD: http://youtu.be/k2kpjZuozHk
    Anybody knows how to solve this?
    Best Regards.
  • how does one change the Propeller start up when armed? i have indicator LEDs that tell me when the craft is armed or unarmed? was it set compassmot to 0? i forgot where that conversation ended
  • T3
    A little off topic but interesting concerning the ArduCopter development:
    http://www.suasnews.com/2013/12/26266/eth-quadrocopter-failsafe-alg...
    The major problem is that "This technology is patent pending." Hence, I m not sure if we will see something similar in ArduCopter-4.0rc8 (I m also not sure if this will work on bigger copters).
  • Hi,
    how can i creat a ROI Mission? Id like to Programm a mission where my copter locks to some preeset directions.
    If i Set Roi events at the planer it does not work... the copter looks to the next waypoint or if I rotate maualy it holds this position... what can i do to preset the direction?
    thanks
    Alex
  • @Randy...
    I've been flying V3.1 rc7 on my Iris, during the developer testing, and It's running great. In mission planner now, loading betas, this version comes up for all configs. Is this real?
    I've got an X8 and would like to try the rc7, so it seems that I should be able to try it.
    A second related question, I have two  Pixhawks coming soon, one of which I want to put into an X8 configuration. And I thought I saw somewhere that The Mission Planner "V" configuration would be used for X8. My new X8 frame is oriented much more like a V than a straight X, and even more-so than the 3DR X8. Does the "V" config adapt to 8 motors?
  • This happened to me too, twice, on a quad, within two flights otherwise great. Then several flights flying perfect after that ... Could not find anything obvious  looking at logs,  Good satellite reception, baro, etc ...
  • Hi Guys! I´ve been testing RC 7 this weekend. So far only one strange issue found.
    While in loiter mode, sometimes the tricopter starts to drift to one side and if I didn´t correct it, it continued to fly away.
    Today there was absolutely no wind, some flights I could leave it there for 10 minutes and I had a perfect loiter, then the problem started.
    Here are some logs (although I´m not sure that this are the ones that show the problem) to see if you can fin anything.
    Thank you very much
    2013-12-02 00-54 10.log
    2013-12-02 00-49 9.log
  • Is there some documentation on the new flight modes in 3.1? Not seeing anything about sport and other new modes here:
    http://copter.ardupilot.com/wiki/flight-modes/
Aug 25
