ArduCopter-3.0.1 released!
Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
3691038784?profile=original
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to Marco, DaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found here, here, here, here, here and here.  Thanks also to MichaelO for the MP changes required for this release.
  • I thought I'd try out the HIL (hardware in the loop) version of  3.1RC8 and FlightGear to test out the hardware and simulate flying. (This is the first time I've tried using this by they way.)  I followed these instructions: http://copter.ardupilot.com/wiki/hil-quad/
    What functionality should work with HIL? I noticed that I couldn't calibrate the compass or accelerometers and that lots of the parameters weren't changing in the Flight Gear HUD. The altitude value didn't change even though I could use the R/C to arm and fly the quad to high altitudes and change the pitch, roll and yaw of the model even though the HUD text values in FlightGear and the MissionPlanner didn't change. I did see changes in the MP's Roll and Pitch graphical display.   (Are most using the software in the loop approach to simulate flying and test firmware as described here. )
    Here's what the HIL setup looked like for me:
    3692896728?profile=original
    3692896639?profile=original
    All with APM Copter V3.1 RC7, Youtube video compressor is horrible, pm me if you want to evaluate the quality of the full raw file.
    For other info see the description in the video page.
  • I made a flight today with ArduCopter 3.1-rc8 9-Dec-2013 on my X8 (a homebulit frame weight 3kg without lipo)
    First I fly stabilize then loiter and when looking at BarAlt-RelAlt it looks fine
    I landed, disarmed, waited 1 minut, armed and then a short flight in Stabilize (i wanted to record the throttle needed for hover)
    The looking at the log BarAlt-RelAlt the BarAlt looks rubbish.
    Both flight was OK, no problem.
    I compiled the hexfile myself and changed "This firmware xxxxxxxx" this to keep a record of what firmware I have compiled.
    I also attached a pic of AccZ taken just 2 minutes before the above flight, then I disabled IMU
    Look at the attached pictures of the BarAlt-RelAlt
    I have also attached both logs.
    3692895883?profile=original
    3692896324?profile=original
    3692895900?profile=original
    2013-12-09 14-38 2.log
    2013-12-09 14-38 3.log
    https://storage.ning.com/topology/rest/1.0/file/get/3692896341?profile=original
    AC3.1-rc8 is available now through the mission planner's Beta Firmware's link.  Not many changes over -rc7 but here they are:
    1) add Y6 motor mapping with all top props CW, bottom pros CCW (set FRAME = 10)
    2) Safety Changes:
        a) ignore yaw input during radio failsafe (previously the copter could return home spinning if yaw was full over at time of failsafe)
        b) Reduce GPSGLITCH_RADIUS to 2m (was 5m) to catch glitches faster
    3) Bug fixes:
        a) Optical flow SPI bus rates
        b) TradHeli main rotor ramp up speed fix
    I'm expecting that -rc8 will become the official AC3.1 release (i.e. just a name change) in about a week.  Thanks for all the testing so far and if anything comes up I'll have a look at your logs.
  • With the problems in loading firmware to my X8 with Mission Planner I started to look for other means.
    I have an Ubuntu on a virtual machine in my Win 7, where I have compiled a project successfully, but so far haven't had the guts to upload yet... besides, I still have to sort out USB connections through the VM.
    So the other means was through the patched Arduino.1.0.3 .
    Here I had a little surprise. 3.1 rc7 compiles "too big". 262,438 KB where the limit is 258,048.
    So question 1) do the linux compilers optimize enough to get the code squeezed into the space required?
    My only other option then is get my linux working.
    Question 2) Do the everyday linux compilers that we have optimize enough to get it into the required space? Are 3DR compilers enhanced?
    I guess we are pretty much at the limit with APMs
    Thank God I've got my Pixhawk!
    Although I've still got an X8 with an APM 2.6 stuck in 3.01!
  • Having a bit of an issue trying to set up a 450 quad for a friend.
    I have loaded RC7 and done all the setups and calibrations.
    It can see many satellites (7-10) and clearly knows  where it it when connected to MP but the HUD says 'no GPS fix'
    OK so now I try to fly in STAB by disabling the GPS failsafe but the HUD still says 'failsafe' when I try to arm. Im assuming its the GPS failsafe still preventing arming as its the only thing in red and there are no other warnings
    CLI test for gps and compass is fine.
    Any ideas?
  • I can't seem to load 3.1 rc7 to my X8.
    First I updated to MP 1.2-88.
    Did the upload as I usually do for my Iris. Connect cable, change port number and baud top right but don't connect.
    Go to load firmware. It loads 3.01. I click "Beta Firmware". and 3.1 rc7 appears.
    I click the X8. Syas "checking board version", and hangs for a good 5 minutes. After a while it will start to load Hex but hangs and then times out. My internet conection is good.
    I tried loading the hex file from code.google, and then "load custom firmware". After a pause, it begins to load Hex, and then hangs about half way through.
    What gives?
    I backed up to MO 1.2.86, but the same thing!
  • Hi randy, it will be nice if user can reduce the copter speed when approaching home during RTL. I want it slow stop.
  • Do any of Us that have 3DR/APM boards ever have to worry about this? http://www.wired.co.uk/news/archive/2013-12/04/flying-hacker-drone Skyjack, Used on PArrot Drones, can hijack the signal of other drones. do we have the same back door on APM Boards? just wondering, not worried? something to think about i guess?
  • 3692893961?profile=originalhello
    -After doing autotune on my Y6   (RTF 5kg,batt 6s8000MAhx2,APM2.0 rc7) i got some realy big values as you can see on picture above.and bcs. i had fast oscilations with this settings i lowered the values for 25%(stab.and..rate)
    -now it is less nervous and realy respond to comands very well but when i roll to the right copter dips down(in stabilize is somehow linear in alt hold its fast drop of 1m until controller bring it back to desired altitude)..if i dont touch anything alt hold is solid and loiter as well(it just hang in the air at same spot,almost perfect)
    -i we noticed that problem before(but before also when i roll left copter goes up,as well roll right copter go down) so i folowed instructions of someone in this thread
    http://www.diydrones.com/group/arducopter-y6-owners-group/forum/top...
    and swap signal wires of motor 4 and 6 also changing rotations of those motors so now i have all props on top spining in same direction and bottom too and now it is better but..my top props are 14x5 and bottom is15x5,5 but since i broke all the other props i had to put same props(14x5) on motor 4 and 6 not 14x5-15x5,5 combination(top-bottom)....it did go thru Autotune without any problem,logs of that is in autotune discussion
    http://www.diydrones.com/forum/topics/ac-3-1-autotune-support-discu...
    -my question is does my Y6 dips down when i roll right bcs of that prop is 14 not 15?
    -attached is my logs from 2 test flights(please do not pay attention to my voltage and current readings since my Attopilot 180A is not the one you can trust)
    -sorry for my bad English and long post
    2013-12-06 12-59 1.log
    2013-12-06 13-00 2.log
