ArduCopter 3.0 is ready for widespread use. To make the transition easier, this time we are asking people to voluntarily upgrade from 2.9.1b for the next month or so before we make 3.0 the default firmware downloaded by the mission planner. The new version can be found in the Mission Planner's Beta firmware's link, firmware.diydrones.com, GitHub and the new Downloads Area.
Warning #1: A bug was found in the FENCE in which if you lost GPS it could lean at extreme angles as it tried to maintain an invalid position. This is fixed in AC3.0.1-rc1.
Warning #2: This release has not been fully tested on Traditional Helicopters
Warning #3: GPS glitches can cause sudden and aggressive position changes while in loiter mode. You may wish to reduce the WPNAV_ACCEL to 100 and Loiter PID to 0.2 (from 1.0) to reduce aggressiveness.
- Inertial Navigation for Loiter and Auto meaning much more accurate control (Randy,Leonard,JonathanC)
- 3D navigation controller follows straight lines in all dimensions between waypoints (Leonard,Randy)
- "compassmot" to compensate for interference on compass from the pdb, motors, ESCs and battery. (Randy,JonathanC) (Set-up video here)
- Safety improvements:
- simple Tin Can shaped Geo Fence
- pre-arm checks to ensure all calibration has been performed before arming (can be disabled by setting ARMING_CHECK to zero). (video description here)
- GPS failsafe - switches to LAND if GPS is lost for 5 seconds
- stability patch improvements to stop rapid climbs in very overpowered or overtuned copters
- Circle mode improvements including "panorama" when CIRCLE_RADIUS set to zero (Randy,Leonard)
- SONAR_GAIN parameter added to allow better tuning of sonar surface tracking
- CH8 auxiliary switch (same features as CH7)
- works on PX4 (some minor features still not available) (Tridge,PatH)
How to upgrade:
1. Make sure you are using Mission Planner 1.2.59 or newer.
http://ardupilot.com/downloads/?did=63
2. Click on the MissionPlanner's Firmware screen and click the "Beta Firmwares" link on the bottom right. The version numbers should update to "ArduCopter-3.0.1rc2", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults. The modified PID values for the 3dr frame can be seen in the image below.
4. If you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware.
http://copter.ardupilot.com/wiki/common-ppm-encoder/
http://copter.ardupilot.com/wiki/common-ppm-encoder-apm2x-atmega32u2/
Special Thanks to Marco, DaveC and the rest of the beta testers for putting their copters at risk during the extended testing period. Some of their videos can be found here, here, here, here, here and here. Thanks also to MichaelO for the MP changes required for this release.
All feedback welcome. Please put your questions, comments (good and bad!) below.
Added by Craig:
Please watch Randy's videos on setting up and flying APM-Copter 3.0 before you go flying. They are excellent!
All,
I am having trouble with telemetry now that I upgraded to 3.0 on my quad.
It works fine and allows me to change the parameters, gains, and view its location, but the left side of the 'flight data' display is not working. It does not show GPS lock (even though it is), the horizon does not work, and no battery data. The rest of telemetry seems to work fine.
Ideas?
Thanks! V3 is looking good!
Randy, is there any special PID adjustment for 880kv motors?
previous version we were suggesting this: (one more time again, this was pre 3.0)
While some testers have reported very good flights with the default PIDs, some have reported that this release is a little "sharper" due to the DCM improvements and have found they needed to:
reduce stabilize P by 10% (i.e. 4.5 -> 4.2)
reduce stabilize D by 30% (i.e. 0.15 -> 0.10)
increase rate D from 0 to 0.001
I've quickly just tested the release on my Hex and loiter held well for a few seconds and then I noticed it started to "orbit". This gradually increased in circumference until I took it back to stabilise.
Any ideas what coul be causing this please so I know where to focus my attention.
Well done again.
Hi Randy,
Congratulation for the team great work ! I just uploaded v3.0, and I was wondering if for logging RAW data it was the same command (enable RAW) than 2.9.1b, because I can't enable RAW, strange ?
One last question, before till v2.9.1b I manage to make my motors spining after arming, with no throttle input. I didn't manage to do that with v3.0, could you tell me how to do that ?
Thanks,
David
solar disturbances page, IMPORTANT:
Are the bars in the diagram on "Green" everything is OK.
If you have yellow or red bars there might be problems with the GPS-signal and the included associated features.
http://www.mikrokopter.de/ucwiki/en/SunStorm
http://www.n3kl.org/sun/status.html
I love this code! Tried it out on my 2kg hexa thismorning, the results were incredible! On default params except for Throttle P which I upped to 7.5. Auto mode was smooth and stuck to the lines. Loiter was rock solid! I was even able to implement auto takeoff and landing: a feature I had never been able to implement because loiter didn't used to be tight enough for me to land without "tripping" over the grass and height hold wouldn't slow it down enough.
Here's a KMX file of a 15 minute loiter that never even strayed a meter! Thank you for all your hard work, devs.
2013-06-18 12-35 4.kmz
Hi Guys, did 2 auto flights today with a big octo (v3 r5). second flight was 11 minutes, 1.4kms at 350metres. Very happy.... I still have some more tuning to do but quite happy so far. the climb and decent still seem a little notchy at the moment. more flights tomorrow weather permitting! will swap over to v6 very soon. Thanks guys!
Randy, did you guys get the auto acceleration parameter in RC6?
This is a can of cool!
Excelent news, been waiting for this release to restart my testing :)
A couple of questions regarding upgrading from v2.8.1 to v3/(rc6) ...
Should I upgrade Mision Planner first to the latest version (1.2.50, currently using 1.2.27) and then go through the firmware upgrade?
Is there a parameter file for v3/(rc6) for the standard 3DR-C quadcopter (couldn't see one in the new downloads area)?
And just one more... I have the Mediatek GPS unit, is there a new/specific firmware version for that that is required to enable it to work correctly with v3-rc6?
Many thanks.
10
11
12
13
14
of 14 Next
