ArduCopter 3.0 is ready for widespread use. To make the transition easier, this time we are asking people to voluntarily upgrade from 2.9.1b for the next month or so before we make 3.0 the default firmware downloaded by the mission planner. The new version can be found in the Mission Planner's Beta firmware's link, firmware.diydrones.com, GitHub and the new Downloads Area.
Warning #1: A bug was found in the FENCE in which if you lost GPS it could lean at extreme angles as it tried to maintain an invalid position. This is fixed in AC3.0.1-rc1.
Warning #2: This release has not been fully tested on Traditional Helicopters
Warning #3: GPS glitches can cause sudden and aggressive position changes while in loiter mode. You may wish to reduce the WPNAV_ACCEL to 100 and Loiter PID to 0.2 (from 1.0) to reduce aggressiveness.
- Inertial Navigation for Loiter and Auto meaning much more accurate control (Randy,Leonard,JonathanC)
- 3D navigation controller follows straight lines in all dimensions between waypoints (Leonard,Randy)
- "compassmot" to compensate for interference on compass from the pdb, motors, ESCs and battery. (Randy,JonathanC) (Set-up video here)
- Safety improvements:
- simple Tin Can shaped Geo Fence
- pre-arm checks to ensure all calibration has been performed before arming (can be disabled by setting ARMING_CHECK to zero). (video description here)
- GPS failsafe - switches to LAND if GPS is lost for 5 seconds
- stability patch improvements to stop rapid climbs in very overpowered or overtuned copters
- Circle mode improvements including "panorama" when CIRCLE_RADIUS set to zero (Randy,Leonard)
- SONAR_GAIN parameter added to allow better tuning of sonar surface tracking
- CH8 auxiliary switch (same features as CH7)
- works on PX4 (some minor features still not available) (Tridge,PatH)
How to upgrade:
1. Make sure you are using Mission Planner 1.2.59 or newer.
http://ardupilot.com/downloads/?did=63
2. Click on the MissionPlanner's Firmware screen and click the "Beta Firmwares" link on the bottom right. The version numbers should update to "ArduCopter-3.0.1rc2", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults. The modified PID values for the 3dr frame can be seen in the image below.
4. If you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware.
http://copter.ardupilot.com/wiki/common-ppm-encoder/
http://copter.ardupilot.com/wiki/common-ppm-encoder-apm2x-atmega32u2/
Special Thanks to Marco, DaveC and the rest of the beta testers for putting their copters at risk during the extended testing period. Some of their videos can be found here, here, here, here, here and here. Thanks also to MichaelO for the MP changes required for this release.
All feedback welcome. Please put your questions, comments (good and bad!) below.
Added by Craig:
Please watch Randy's videos on setting up and flying APM-Copter 3.0 before you go flying. They are excellent!
I just added this note to the discussion but I will also post the information here for those of you getting email updates.
Added by Craig:
Please watch Randy's videos on setting up and flying APM-Copter 3.0 before you go flying. They are excellent and will help everybody.
I have just returned from field.
Have tested ACM 3.0.0. From beginning I was pleased - just glitches of motors that could be because of vibrations - I have no anti-vibration setup. Then I was going to switch to loiter. Just before I touched the switch quad dropped down suddenly 2-3 meters. I remained in STAB mode and then came next drop down. Fortunately had enough hight so didn't hit the ground.
Anyway level of adrenaline jumped too high. Rest of the flight was the fighting with unexpected level drops.
If enyone can help me what I'm doing wrong would appreciate it. Here is the log.
2013-06-19 20-03 2.log
Randy and Dev Team,
Just need clarification regarding INS_MPU6K_FILTER setting.
I noticed that in 2.9.1b release the INS_MPU6K_FILTER setting was changed to 20hz as per the release notes.
Now with this release 3.0 in the Mission Planner, in the Advance Parameter List under the description for INS_MPU6K_FILTER, it reads that this setting should be set 42hz for Arducopter and 20hz for Arduplane. However, there is no mention of the INS_MPU6K_FILTER setting being changed back to 42hz in the 3.0 release notes.
Which is the correct INS_MPU6K_FILTER setting for the 3.0 release for Arducopter, 42hz or 20hz?
I commend you all for this release.
Thank you!
By descriptions it promises a lot over versions till 2.9. Will going to test it in the evening.
But what I understood from Randys writing when I touched some param it will stay untouched by loading new firmware. I have touched some and want to start testing ACM 3.0 with defaults. Do I need to reset them somehow or can somebody upload here the default params ?
Hi Randy and Dev team.
Finally.. it's definitely comparable with Naza now, thanks for the hard work.
On last RC5, I notice that if I set waypoints (without any RTL on it) and click on "Write WPs" button then my RTL_ALT parameter will be set to 10000 (100m) even if I had it on zero before and it's same value as Default Alt on Flight Planner. Is it bug ?
Thanks in advance.
Team Land. It was he who sits at the penultimate point waypoint or point of land if there are its coordinates.
Hi
Thanks for all the info, its help me to solve the problems with my quad.
where can I download the Mission planner 1.2.53 mav 1.0?
where I define the fence radius. Is the radius is always from starting point?
Itzik
I made a mistake when doing the release and accidentally released out of our master branch instead of the special purpose ArduCopter-3.0 branch. The effect is that an untested feature called RCMAP (which allows the pilot to configure which input channel is used for roll, pitch, yaw and throttle) got into the release.
I've just updated the version coming out of mission planner so that the feature is removed. I don't believe there is any real danger but if you've loaded AC3.0 between now and when I created this thread (about 1.5days ago) I'd like you to reload AC3.0 at a convenient moment.
Sorry!
Hi Guys,
Thanks for the hard work and new killer release. I've tried rev.3 since rc2 and have flown every rc up to rc5 on my big H quad(Galactica).
I took up rc5 yesterday(not sure what has changes to release 3.0.0) and experienced the great stability in alt hold and loiter. I set the quad in loiter for a few minutes. I then performed a few yaw's whilst in loiter. She did the yaws without event, but a few seconds later dropped about 5meter. Recovered, and dropped again. I went back to stabilise and did a manual hover and alt hold for another 12 minutes(battery issue ruled out).
Would this behaviour be part of warning 2?
(Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode. You may wish to reduce the WPNAV_ACCEL to 100 and LOIT_SPEED to 400 to reduce aggressiveness.)
Thanks, Antonie
10
11
12
13
14
of 14 Next
