ArduCopter-3.1 released!
After months of testing AC3.1 is finally available in the Mission Planner and GitHub.
Warning #1: If the vehicle is left landed (but armed) while in AltHold or Loiter mode for more than a few seconds, the vehicle may suddenly jump into the air the moment the pilot raises the throttle above zero.  The reason is the baro altitude may fall while the vehicle is sitting on the ground.  In AC3.2 this bug is fixed because we reset the target before take-off.
Warning #2: Motors will spin (slowly) by default as soon as the copter is armed!  You can switch this feature off by setting the MOT_SPIN_ARMED parameter to zero.
Warning #3: if you see "Bad Gyro" on the HUD then you may have a blown 3.3V regulator.  See this thread for details.
Warning #4: if you use a sonar set the SONAR_GAIN parameter to 0.8 or lower
Warning #5: Trad Heli users should now connect their main rotor ESC to APM's RC8 output
Warning #6: Trad Heli BUG causes loss of collective control in ACRO mode if swash type set to flybarred (i.e. not flybarless).  Will be fixed in AC3.2.
The major improvements over AC3.0.1 are (full list here):
1. Pixhawk support (Tridge & PX4 development team)
2. Autotune of Roll and Pitch gains (Leonard/Randy)
3. Drift mode (Jason)
4. Improved Acro (Rob/Leonard) and new Sport mode (Leonard)
5. Arming, Take-off, Land in Loiter or AltHold
6. TradHeli improvements (Rob) including:
a) support for direct drive tail rotors
b) smoother ramp-up of main rotor
c) reduced collective for better control in stabilize mode (STAB_COL_MIN, STAB_COL_MAX params)
7. Support for SingleCopter (Bill King)
8. Performance improvements resolve AltHold troubles for Hexa & Octacopters
9. Safety Improvements:
a) GPS Glitch detection (Randy)
b) Motors spin when armed (Jonathan Challinger)
c) crash detector shuts off motors if copter flipped for 2secs
d) batt failsafe option to RTL instead of LAND, gps failsafe option to trigger AltHold instead of Land
e) more pre-arm checks of inertial nav speed,
10. Bug fixes:
a) optical flow working again (although performance is still not great because not integrated with inertial navigation)
b) ROI working (use DO_SET_ROI command)
How to upgrade:
Click on the MissionPlanner's Initial Setup >> Install Firmware screen.  The version numbers should appear as "ArduCopter-3.1", then click the appropriate frame icon and it should upgrade as per usual.
Special thanks to Marco and the many beta testers on the AC3.0.1 thread who put their copters at risk during the testing of this new version and uncovered many problems so that you don't have to!  Here are some of their videos: loiter in wind, patio sonar, autotune, autotune2, roi, beach, acro, vrbrain, tricopter, train spotting, radio failsafe, the tree, double loiter
If you haven't seen it recently, please check out the ArduCopter wiki.
Feel free to post comments below and we're going to use the new APM Forum for support issues so please post your support requests there.
  • ArduCopter 3.1 Traditional heli will destroy your heli if you manage to fly unarmed in stab mode and switch to AltHold. As soon you switch to AltHold the collective pitch will go to the minimum position, and drives the heli like a rocket into the ground.
    It happened to me. The heli flew like a dream in stab mode but unarmed until I tried AltHold.
    You are able to get collective pitch if unarmed, so you not realising that the APM has, after a while disarmed again. ArduCopter 2.7 allowed NO collective pitch if not armed.
    ground.it
    • I am actually tuning my heli, it flies ok in stab (I am not done yet), but even when armed I get the same behaviour from althold that will swing the collective to full minimum (fortunately, unlike you I tested that on the bench and did not crash). I am still looking for a solution. It has to work, others did it.
      I route the esc through the apm, so it has to be armed to fly.
      • Ok, my error. It has to be armed and the motor has to be activated in order to have althold working. I tought that having the copter armed on the bench was sufficient to verify the switch between modes, but it was not.
        So, I just disconnected the motor, armed the copter, activated the motor switch and checked that althold was handling the collective in a coherent manner. Bench test successful.
        I tried it outside for real, excellent results.
        I might be over cautious, but as we say, better safe than sorry !
        JL
  • Randy, two weeks ago I asked for help because I was having a message "bad compass health" using an external mag. Ended up I changed the external mag for another one, same type, and problem is gone. No more error messages. Maybe i just had bad luck with that first external mag.
    APM now its working pretty good. No more heading problems, loiter is perfect (outperform my naza at strong wind), no more TBE, no more yaw problems. You guys did a pretty damn good job. Thank you.
    Only problem i am facing now (last one) is when the quad hit the waypoint it drop from sky and when it almost hit the ground it goes up fast back  to the right altitude and go to the next waypoint. It is behaving like that when reach every waypoint. Could be a problem related to an uncovered barometer?
    My best regards,
    pampaflyer.
  • Can we Add an Explanation of Thr_IN THR_OUT to the Log Diagnoses Wiki http://copter.ardupilot.com/wiki/common-diagnosing-problems-using-l... ? I forgot what it means When ThrIn Is above ThrOut. am i under powered? How do you correct that? Change THR_MID? i dont think this counts as  a support question on firmware 3.1, thats why i asked it here? thanks in advance
  • How is the sonar on this version? On my 3.0.1 it isn't great but other than that I have a perfect flying machine.
  • I'd like to Thanks TEAM Arducopter, my XAircraft X650 flew Wonderfully today With 3.1 firmware and i didnt change a thing from original settings. Thanks for all the work you guys do, it sure shows!! My F450 Flew pretty good despite a Loose Motor which i didnt notice until after an auto trim. But at least i have that answer now! time to 1UP the F450 Motors & ESCS
    Please stop posting support requests to this blog.
    Every release we have dozens of complaints about how difficult is is to follow support issues through the blog.
    We have created a support forum where issues can be searched, tracked, and managed.
    If we are every going to make the support work more efficiently we have to move away from here.
    Please post your support requests to
    http://ardupilot.com/forum/viewforum.php?f=25
    Thank you all for your help in making this happen.
  • Has anyone experience this problem on their mission planner upon updating to version-1.2.89? Flight Modes are blank! What Happen?
    https://storage.ning.com/topology/rest/1.0/file/get/3692902088?profile=original
  • It still perfect. I have new battery it can hover about 30 mins with 4s 8000 mAh 30C.1003569_790087904351719_778948228_n.jpg
    2013-12-18 10-48.log
    2013-12-18 10-48.kmz
    https://storage.ning.com/topology/rest/1.0/file/get/3692902082?profile=original
