After months of testing AC3.1 is finally available in the Mission Planner and GitHub.
Warning #1: If the vehicle is left landed (but armed) while in AltHold or Loiter mode for more than a few seconds, the vehicle may suddenly jump into the air the moment the pilot raises the throttle above zero. The reason is the baro altitude may fall while the vehicle is sitting on the ground. In AC3.2 this bug is fixed because we reset the target before take-off.
Warning #2: Motors will spin (slowly) by default as soon as the copter is armed! You can switch this feature off by setting the MOT_SPIN_ARMED parameter to zero.
Warning #3: if you see "Bad Gyro" on the HUD then you may have a blown 3.3V regulator. See this thread for details.
Warning #4: if you use a sonar set the SONAR_GAIN parameter to 0.8 or lower
Warning #5: Trad Heli users should now connect their main rotor ESC to APM's RC8 output
Warning #6: Trad Heli BUG causes loss of collective control in ACRO mode if swash type set to flybarred (i.e. not flybarless). Will be fixed in AC3.2.
The major improvements over AC3.0.1 are (full list here):
1. Pixhawk support (Tridge & PX4 development team)
2. Autotune of Roll and Pitch gains (Leonard/Randy)
3. Drift mode (Jason)
4. Improved Acro (Rob/Leonard) and new Sport mode (Leonard)
5. Arming, Take-off, Land in Loiter or AltHold
6. TradHeli improvements (Rob) including:
a) support for direct drive tail rotors
b) smoother ramp-up of main rotor
c) reduced collective for better control in stabilize mode (STAB_COL_MIN, STAB_COL_MAX params)
7. Support for SingleCopter (Bill King)
8. Performance improvements resolve AltHold troubles for Hexa & Octacopters
9. Safety Improvements:
a) GPS Glitch detection (Randy)
b) Motors spin when armed (Jonathan Challinger)
c) crash detector shuts off motors if copter flipped for 2secs
d) batt failsafe option to RTL instead of LAND, gps failsafe option to trigger AltHold instead of Land
e) more pre-arm checks of inertial nav speed,
10. Bug fixes:
a) optical flow working again (although performance is still not great because not integrated with inertial navigation)
b) ROI working (use DO_SET_ROI command)
How to upgrade:
Click on the MissionPlanner's Initial Setup >> Install Firmware screen. The version numbers should appear as "ArduCopter-3.1", then click the appropriate frame icon and it should upgrade as per usual.
Special thanks to Marco and the many beta testers on the AC3.0.1 thread who put their copters at risk during the testing of this new version and uncovered many problems so that you don't have to! Here are some of their videos: loiter in wind, patio sonar, autotune, autotune2, roi, beach, acro, vrbrain, tricopter, train spotting, radio failsafe, the tree, double loiter
If you haven't seen it recently, please check out the ArduCopter wiki.
Feel free to post comments below and we're going to use the new APM Forum for support issues so please post your support requests there.
I have no problems with guided Mode.APM and Pixhawk works fine in 3.1.rc2. Follow me at 3.01 APM no problems. 3.1 not tried yet.
http://youtu.be/sQrlqXQ5O8g
greeting
I mean first time and change new position before go to old position only. It have swing.
I have tried this morning with Pixhawk no problems. Copter in Loiter new position on laptop, copter goes to the new location. waiting for new position.
No problems
greeting
Rainer
Hi Randy,
I will report to you about Bug with change to Guided mode. When i will change to Guided (Click Fly to here with Map on MP) my quad, It like jerky or over swing on the air. And sometime, I have change Position is before move to lasted point. It have break and almost a backflip. But, Today i have loiter so longtime is no have problem and after change to Guided mode is have jerky and backflip have crash. I very lucky not damage on my quad.
I can't sent my log. Because, I used Pixhawk my logs have big size about 12 MB.
Randy
I attached my log have crash with Guided mode on Google drive.
https://docs.google.com/file/d/0B9RZbAMTlAOdc2tiUURuRkowNlU/edit
Hello,
I have activated logging of motors, IMU and compass. In this picture when flying forward there is some unwanted roll and yaw.
Motors look good to me.
Thee gyro "sees" the yaw as you can see in the images (i hope gyro units is rad/s). Also the Acc notices the roll but it is not corrected
I have no idea how to interpretate the compass values. Can this be due to bad compass calibration, compass mot or compass declination? Can I fly with a deactivated compass in stabilize?
edit: this is a reply to this: http://diydrones.com/xn/detail/705844:Comment:1551039
2014-02-06 16-54.log
I loaded up 3.1.1 10 days ago and while the Hex flew exactly as it did before in stabilised, I tried alt hold, loiter and they worked fine as well. I selected land and the descent was unusually high so I flipped back to stab and landed. I checked the full parameter list and it was as it was before, 38cm/s. I was flying out for work so I packed it away till I got back home spending a fair bit of time thinking why that had changed.
I got the Hex out today and before flying I went into the full parameter list and refreshed the parameters and went for a fly and land was back to how it was before.
I have no problems with differential temps of motors or ESC after 10 minutes of flight time.
There maybe a message for others in here, as I also updated to version 1.2.93 of MP, maybe the 1's and 0's got a little bit fargled.
So i posted this elsewhere but no-one seems to have seen it... So i thought i would post here see if anyone can help
Hi folks
So i took the pixhawk out for a flight, everything working ok.
Flying beautifully, attempted the auto tune but too much of a breeze to keep it in the one place.
So i keep flying it, no problems, then out of the blue it just flips and crashes to the ground, luckily not from too high up.
So i try again at low height, this time taking off then it flipping on me.
Any ideas?
2014-02-02 15-28.log
2014-02-02 15-32.log
This is during bench testing on pixhawk with 3.1.2rc1(or whatever is the freshest). With roll 180 on the ahrs.
Hi Randy,
Can you have a look into this log from the pixhawk.
Was hovering for 1 minute and suddenly its flips over a run into the ground.
I cant find a problem in this log, pixhawk with 3dr external gps/compass
Posted it on the following link
http://ardupilot.com/forum/viewtopic.php?f=25&t=5995
