ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
          • I also saw this pulsing only in Auto mode on 3.2rc1, but I described it as a 'pitching' motion.
            I now have loaded 3.2rc2 but have not retested since.
            Martin
            • pulsing is a serious problem. Imagine flying in auto mission then all of a sudden this happen? That's a total disaster! so it's important to know it's origin or cause.
          • @Henri, sorry on putting this question in your thread.
            Yes your right, I'm asking that in general. So to avoid that in the future.
      • Oops..
        In the file 10-05-32 you can see STA, Alt hold,Hybrid
        In the file 10-35-13 the short mission and the thr out pulsing is visible..
        Hope this helps
        Thank you randy.
        Henri
        _logs.rar
      • Hi Randy I did "rar" the two .log files.. not sure in which is the short mission..
        Thank you for your time.
        Henri
        _logs-30-May-14.rar
        https://storage.ning.com/topology/rest/1.0/file/get/3702653071?profile=original
  • Just do a DO_SET_ROI with all parameters set to zero, this will cancel the previous DO_SET_ROI.
    Umm... this was meant as a reply to http://diydrones.com/xn/detail/705844:Comment:1674176... guess I should enable Javascript.
    • Hopefully it will get added to the Wiki before the official release as there is no way of knowing that from this documentation http://copter.ardupilot.com/wiki/mission-command-list/#Do-Set-ROI
      I do prefer the new way on 3.2 where it holds the ROI thru all waypoints once it starts, way better than having to put it in every waypoint, but I still think something like a Do-Cancel-ROI would be more intuitive than setting all 0s for canceling it.
      Thanks Fabian for the info, Ill try it out.
  • First, I thank all the folks who are working so hard on 3.2. It looks very exciting. One issue I see looming in the very near "drone" future is safety. We are one serious accident and one lawsuit away from a lot of headaches. I'm not sure if this is the right forum to post this but, is anyone working at incorporating the new quad failure stability algorithms (in case of a lost motor) in to the APM or Pixhawk? I'm guessing only the Pixhawk would have the horsepower to implement this. Link here...
    http://www.gizmag.com/quadcopter-failure-algorithm/30031/
    I'm very interested in this.
  • Is there anybody who already did a comparison of the PWM output signals with osciloscope? (APM and Pixhawk)
    Emin, you know, we can change the PWM positive and negative with BlHeli, right?
    So many posts about motor/ESC issues at the moment...
    I'm little scared to fly with new pixhawk when it arrives.
    •  just cant stop watching his amazing videos
      here is gimbal view , BLG at work...
      mwc hexa // blg flipI
