ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        Felixrising,
        The issue is that in the mission planner radio configuration screen the meaning of the channels is not changing.  So even when using RCMAP, you won't see the green bars move any differently.  channel 1 is still channel 1, etc.  It's just that the use of channel 1 changes.
        I've raised a mission planner issue here.
        • That is very interesting. So APM Planner just isn't updating the meaning any more even though it is changing within the Pixhawk/Arducopter firmware? Hopefully that will get updated soon, it's quite disconcerting, so I won't try changing things and changing it by trial and error.
          Thanks for the reply Randy.
  • EKFCHECK_THRESH, it seems to me that the repeated errors from EKF regarding compass comes from the fact that few people (like me) don't make a "compass mot" to calibrate the Pixhawk built-in compass  .... because usually we use the compass integrated to the GPS, it was deported and undergoes less deviation.
    How to disable the EKF compass?
    EKFCHECK_THRESH 1? But it was not really a solution ... because no more EKF and for all sensors in this case.
    It would be interesting to propose two solutions:
    simply disable EKF for yaw control via a parameter.
    or for those that want realy high reliability on yaw control it's perhaps possible to connect a second external compass on the I2C bus, and simply disable the onboard compass on pixhawk to have an effective EKF.
    • This reply was deleted.
        • Terry,
          With all due respect, your quad did NOT crash due to magnetic interference.
          Until now, my quad flew with an APM 2.5, mounted directly above the PDB.
          Yes, I did see an improvement with an external mag this weekend.
          But nothing life threatning
          And I'm still flying fixed wing with APM 2.5, successfully.
            • Hi Terry,
              Do you fly with telemetry connected to a notebook or tablet?
              A buddy of mine had a flyaway today, and during the event, Mission Planner reported "Bad GPS Health"
              And obviously then RTL won't work........
              He also had a crappy "HD" camera fairly close to both the RX and GPS, and since I previously had a problem with a HK Wingcam almost killing my quad, we are wondering....
              Both instances we at least had some information pointing to possible causes.
              Hope this helps.
    • I am on apm and usins external mag/gps compas mot barelly ragisteres at 100% throttle even at 6s. Also copter has much more pricise direction hold on 3.1.5 than on any 3.2-RC. Also, as mentioned earlier by me and raph at 3.2-rc4 compas calibration doesn't give same results on the repetative calibrations, some results vary by 20-30 points. When doing 4 compas calibrations with 3.1.5 results are with 1-2 points and most often stay thw same. The problem I think is in the way 3.2 handles magnetometer.
  • Hi all, I was conducting rehearsals with a gimbal, but the engines of height a few feet of my multicopter went away, I was just taken off and stabilize.
    Fortunately no damage ... but it's really dangerous!
    Randy Take a look at my log, in the final part are interrupted, however, we see that the accelerator in / out were aligned.
    I noticed when I recovered the model that the APM had red light (as if it was armed).
    LOG: https://docs.google.com/file/d/0B6QJRmFQmku9eXpnYl9IYkNOOWs
    VIDEO:  https://www.youtube.com/watch?v=6lJnt-p4l3I&feature=youtu.be
    • Is your APM working again? no problem to make another flight? maybe that there was a fail of the 5v power supply or voltage regulator on APM board...
      • you can supply a fault of the APM, the last vcc voltage is detected 4,96volt then I had the impression of a freeze, because even when I recovered the model apm had the red LED on and not blinking blue LED (GPS) off. Today I investigate with the same configuration but this time a few inches from the ground.
        Note: (The power module is original 3DR)
      • I do not think it is a battery problem, I have yet to calibrate the current sensor, but in addition to telemetry apm, I had the data of the voltage of my aurora 9 with optima 9 and if I remember correctly was around 10,7volt. The alarm is set to 10.5V.
        However, even if it was a problem of voltage drop as there simonk should not disconnect the power to the esc!
        But I noticed that all 4 esc went off at the same time!
        Today I try again, I have not flown after the crash and the battery is not fully charged, tried again to check the voltages but I think that the problem is elsewhere.
