ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • Looks good. I am pretty sure it would look much better at the scene. Just can't imagine how strong the wind is through the video.
      Do you have a loiter video in calm weather?
      • Every once in a while I get to fly in calm winds, but Oklahoma is know for its winds.  Trad helis have a high wind tolerance.  Winds gusting to 30 knots don't seem to be a problem.
        I'll put up a calm wind vid next time I get one.
        • Thank you Ray. I will be waiting for it...
  • 3.2rc14 on Octocopter X8, Pixhawk internal compass only, breezy conditions.
    Stab, AltHold, PosHold, Land, PosHold takeoff. Using EKF with no
    issues, performed 'as advertised'.
    Regards to Randy & all Devs.
  • Randy
    Just wondering if the issue about starting up on a moving / rocking boat is something that is on the horizon? Thx
    • Richard,
      I believe Randy stated several posts ago that it will be on his version 3.3 to-do list.
      • I didn't think it was even possible. But if Randy says so, then I there is hope for sure...
        I will look for this...
          Alex,
          I've talked with Paul Riseborough who is our EKF expert and the idea is that we make the gyro calibration very long.  Perhaps many seconds long to allow the boat to do several rocks back and forth.  The length of the calibration might be set by a parameter or perhaps we could ask the EKF itself if it's "variances" are small enough that we can assume that all the sensor data and offsets are consistent.
          • What about an audible [ and LED flashing ] warning, upon trying to arm, indicating the craft thinks it's not level? So you would know there is a problem if you are in fact starting out level yet it’s complaining it’s not? I’d prefer a fix but this could at least avoid the uncertainty until there is one. I ended up arming then throttling up a bit while I hold it. It would be pretty obvious at that point if it was way off. Not a very safe or pragmatic solution though. I can see the param now,,,  Dummy_on_boat_with_$3000_Flying_electronics   1 yes 0 no ;]
            • Surely the answer is always "yes" :) .... And yes, the audible or led would be a good addition. Okay, okay, I can hear it now to the tune of the love boat theme.
