ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • @Randy
        screen shot my altitude. and during copter bumping to land, i try POSHOLD to takeover the throtle, but failed. seems RTL/LAND  continue his job.
        attached log
        LAND SPEED 50
        WP SPEED DN 300
        3702673754?profile=original
      • Randy,
        Could this also caused by the copter being close to ground?
        I see bouncy landings with low profile copters a lot. When the baro sensor is very close to ground the sudden pressure increase deceives the baro sensor. Raising the platform (ex: by using a landing gear) solves this issue most of the time.
        But I also see perfect landings on many low profile multicopters (which don't use a raised landing gear assembly) as well so the land_speed parameter that you talking above could be the main reason.
          Alex,
          Ah yes, you're right.  Another possibility is a baro disturbance near the ground.  There was a tri-copter report a few days ago in which baro alt drop by 4m when it came close to the ground.
  • Just put RC14 on my tricopter.  Redid all my calibration and im getting "prearm check fs_thr_value" warning for my prearm check.  my throttle off pwm is 982 and on is 993.  Failsafe is set to 984.  Any ideas?
    I would use my frsky x8r with sbus for failsafe but even though MP shows the  the pwm change from the x8r with its failsafe being set it wont engage the flight mode so im stuck doing it with mp
    • I found in setting mine up that fs_thr_value had to be at least 10 less than the throttle minimum value. I had to use the throttle trim on the transmitter to get it high enough to avoid the message. Looks like you need to adjust your transmitter trim to make your minimum at least 994 or more.
      • I pushed my trim to max and redid the radio calibration and im good.  Thanks!  Maybe this is something that could be addressed?
        • There is nothing to address, the code is doing what it should.  Instead of adjusting the tx trim, you may consider setting the throttle travel (on the "servo's" page in the FrSky to a lower number, say 80% ) so that at center trim, the pulse widthis 1000 (1ms) or more at minimum... and make sure it doesn't go over 2000 (2ms) at full throttle.  You will need to redo the radio call in the APM set up once you do this.
          Steve
          • Thanks for the response steve.  Another question.  whats the problem with exceeding 2000?  My taranis hits 2006.
            Jeff
            • The timing of the rc pulse stream can experience problems if the pulse width exceeds 2ms.  This happens because the 2ms pulse hasnt ended before the next pulse starts.   This problem can occur in the ppm stream decoded in the pixhawk or in the rc reciever.
              To see this in action use a exuhf module in the taranis   if you set a few chanels to more than 2ms you can change flight mode (ch5) by moving channel 4 (rudder).
              The last thing you want in anything that flies is unreliability.   Keeping each pulse in your pulse train between 1 and 2 ms   helps keep the rc link reliable.
              Steve
Laurie J. Troy liked Jasper Kueppers's profile
Apr 1
Timothy Miller liked Joseph Udofia's profile
Mar 18
