ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • Is POSHOLD mode in RC14?
      I only see "POSITION" and when I set that as a flight mode and flip my mode from stabilize to position. It does not show "position" as the flight mode in flight data.
      • I got it fixed. Had to update MP to latest beta and i saw back POSHOLD
      Please download 3.2 from the Beta menu.
      You can verify the code version by either looking at the messages received from the vehicle when the telemetry connects or by looking in the log file.
      Recalibrating your compass is required.
      • My compass calibration seems to be very fast. It normally takes long to complete.
        Is the new versions now faster with compass calibration ?
        • Yes the new Mission Planner ...I my case with pixhawk also less accurate. The Copter is yawing much more after new calibration. I did it several times with no good results.
        • Yes, it has been changed so it auto completes when it has enough data.
  • No its working normally, it show  north correctly compared it with analog compass.
    • If tou read back some N amount of pages there was a discussion about demagnetizing the screws wich held pixhawk inside the case. I suggest first demaging those. Apperently some units are being assembled with a magnetized screw driver, this leaves the screws slightly magnetized. I actually had to heat up the screws till they were red than let them cool down,  this works too :)
        Yes, I agree with Artem that it's most likely the screws in the case that are magnetized.  If people are finding the screws are magnetized it would be great to complain to the manufacturer of the boards.
        My guess is these boards are not 3DR boards (I've already checked with 3DR that they do not use magnetized screws) but if by chance they are, I think Craig Elder could help us work back to find the problem in manufacturing.
        By the way, I think it's really cool and interesting that you thought to use a tape demagnetizer to fix the problem.
        • I'm a bit late here - can't follow everything!
          BUT, I wonder whether anyone actually tests their MAG after calibration, to see whether headings are accurate. You need to do it on a tripod according to my procedure at
          http://diydrones.com/forum/topics/apm-and-compass-calibration?comme...
          I found on several occasions that his "manual" calibration method can improve upon the offsets provided by the normal calibration procedure from MP.
          I'd be very interested to hear whether others find some heading errors and can correct them as I did.
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
