ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • Crash on AC3.2-rc14: Unexpected flip with a TBS Discovery Pro
    I crashed 20 minutes prior due to a silly mistake (took off straight after a RTL and forgot I was in Acro Mode), replaced two broken props, tested the motors, confirmed that Mission Planner HUD displayed the correct angles and headings and it looked good to go again.
    I took off in Loiter mode (line: 12.5*10^3) and let it hover under 3 meters without control inputs.
    About 30 secs later, just as I started to provide control inputs, it unexpectedly flipped over diagonally and crashed into the ground, as if a motor failed.
    It was not a mechanical failure, as after inspection, all motors were functional, all cables plugged in, all props tight. Apart from the external compass+GPS, which came loose, I flew it again today without any changes.
    EKF was disabled.
    I went through the logs and couldn't find any clues... Hoping that someone with more expertise than me can provide some insight into the data. Thanks!
    2014-11-19 09-00-00.log
  • With everyone talking about calibration and ways to do it does anyone have a set of ranges we should be looking for? There are many ways to manipulate getting numbers but which ones are right? Is it still anything below 250 is good?
  • No Position Hold!
    MP 1.3.14 build 1.1.5436.9174
    ArduCopter V3.2 (c8e0f3e1)
      You need the beta of MP to  see Pos Hold
        Craig,
        I just checked and the "stable" release of MP right now is 1.3.14 build 1.1.5436.9174 while the Beta version is 1.1.13 build 1.1.5432.12651. Not sure what's going on there.
        Nathaniel ~KD2DEY
          That means Michael pushed a change to Master but has not updated the Beta branch in github
        • Yep, that and the update prompt got me again today!
      • Craig, is it possible with MP to detect the version/build of arducopter code and check if the installed MP version is compatible with that firmware.
        If not, purpose downloading the right one (it could be upgrading even downgrading for example if lastest MP version would not be fully compatible with previous AC version... normally lastest MP version should be compatible with every AC FW).
