ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • that is awesome :). where did you grab the  Ublox-Neo-M8N?
      edit: woops read up, i see it now  http://www.csgshop.com/product.php?id_product=173
        ordered one - I have to try it out :)
        • This reply was deleted.
          • How about apm counfiguration? Could you tell me the wiring for apm? Thanks
            • Christian! Another problem that I noticed is, a random flashing in the reception of the satellites, suddenly the satellites do not appear in Mission Planner and in less than a second, reappear again.
          • Many thanks chris...I will order one
  • @christian, so what i understand is Ublox-Neo-M8N is plug and play with pixhawk. all one has to do is connect GPS and compass (i2c) connectors. is that correct?
    • could you share you ublox txt?
    • Where did you bought this gps? Would you like to share the link?
    • Hi Christian! I also have this GPS and I had the same results in a test that I realized before flying, but unfortunately I was playing with the pines of connection and damaged the tracks of the plate and after a lot of work I could weld them and it works, but when I prepared to prove the Quad, I could observe problems of instability in Loiter and the quad was presenting very strong drifts in some directions. If you've done some flights with this GPS, I'd be happy to see them.
      https://www.youtube.com/watch?v=4zpPm7U67uA&feature=youtube_gda...
