ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
                • That rc in rc out and baro alt
              • Frustrating... I'd say it's a Mac pc thing but it's right on the card like that.
  • Using IRIS+ factory transmitter and receiver 3.2rc14 worked great, I wanted to switch to my DX9 and spektrum satellite receiver.  Now the IRIS+ hunts and doesn't hover, I constantly have to change throttle in stability mode.  It also begins to climb at about 30% throttle and in Loiter mode it descends in steps until it lands.
    I've gone through the calibration wizard a couple of times, I've set CH6,7,8,9 to do nothing.  I've reloaded the IRIS+ default parameters.
    Any ideas on anything else to try before I revert to using the factory tx/rx?
    • To answer my own question doing an ESC calibration appears to have resolved the issue, at least in the garage.
      The props also now spin on arm which also wasn't working until the ESC calibration.
  • Several auto flights, stable, alt hold, pos hold, land... no issue. EKF on. Incredibly smooth.
  • Hi,
    I have a problem that I cannot arm my copter any more.
    There are no prearm errors, it just refuses to arm.
    I had some problems with a (pitch/roll) gimbal on my 9xr Pro transmiter, that I sorted out - a loose potentiometer.
    After fixing it I did the radio calibration and the problem showed up.
    I have tried loading some default parameters, with them I could arm, but then I had another problem.
    I could disarm the motors (the red light flashing) but the motors would continue to run at slow speed.
    If I change the RC3_MIN the motors will stop but I can't arm again, so it seems to me that there is a problem with my parameters, but I not able to sort it out where.
    I am attaching the params and logs (on the bench).
    Thx.
    MyBadParams.param
    2014-11-22 18-21-42.rlog
    2014-11-22 18-21-42.tlog
    https://storage.ning.com/topology/rest/1.0/file/get/3701880169?profile=original
    • Strangely enough, the problem went away this morning.
      I tried to arm it and succeeded?!
      The only thing that's different from yesterday is that I didn't connect it to MP.
  • Will 3.2 be beta forever?
    Greetz Chris
    • About 2 weeks ago it came out of beta.
      • It is still Beta but in the final phase they are being extra careful before it's the official release
