ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • FYI.... WAAAAAAyyyyyy back in this thread somewhere I posted a problem about and issue were after going to 3.3 from 3.2 my teesny and lue script for my taranis telemetry was broken. It worked fine until I fired up a GCS station the instant I did that and connected the Taranis telem acted weird... useless. I FINALLY figure out it was because I needed to snip the red wire [ and I didn't blow up yea!!] which was the TX from the teensy RX on the tellem 2 on the pixhawk. Now it seems to work fine. If anybody knows why that is I would sure like to know!
  • Can someone please tell me how to skip just the gyro calibration pre-arm check? If I set pre arm check to '0' that disables all of them [ compass etc ] but all I want to do is skip just the gyro. I need to do this to arm on a moving boat until 'boat mode' gets the green light in 3.4. I hope...
    • https://github.com/diydrones/ardupilot/blob/ArduCopter-3.2.1/ArduCo...
       ARMING_CHECK_INS = 0x10
      Although note this skips all the INS checks including accelerometers.
      Also note that in 3.3 these checks were specifically strengthened to fail pre-arm checks if the FC is moving over a certain threshold when arming such as on a choppy boat, as if this is allowed then as I understand it the FC can't then keep attitude control.  In other words, bypassing this is a Very Bad Idea :)
      • Thanks. Yea I agree probably not a good idea. Guess I'll wait for a better solution in 3.4
  • Having issue getting MP to georeferenced my images using the post processing tool  (Ctrl-F).
    If i tell it to use the CAM messages it errors out and just says aborting.  I had MP take the pics are preset distance intervals during the mission.  Pictures are fine.
    If I tell it to use a time offset and the do the estimate Offset command then it runs fine and tells me the offset is 1179.592
    I then add this value to the Seconds offset. I hit the Pre-Process and below shows me the pic are found and at what ms away value.  I then click on Location KML and in Google earth it appears all photos are right over the Home/start position?
    I then click on GeoTag and it sits and processes as it should. When I look at the Geo data inside each picture they are all the same.  Looks like it has assigned the location or either Home or the ground station for each picture time.
    What am I missing?  Again I had MP trigger the camera during the mission.
    Bill Neuhauser
    • I'm still encountering a similar issue with the Geo Reg Images utility in MP-1.3.32. Pre-process appears to only work for me when 'Use AMSL Alt' is unselected. If this is selected, the utility prints the error "Log file problem. Aborting". I'm still using AC3.2_RC10, and wondering whether there's been a change in the position (log offset) of the AMSL value in the logs?
  • @Glen M, Thanks for that. I have worked out how to use U-Centre. I can change the baud rate and then reconnect. The comms link is flashing green and I can read the data in the text window. . I can see the sat data, etc after re-connecting. Once I disconnect and lose power. The baud rate goes back to 57.6k.
  • Can I briefly take the discussion back to the M8N? I have bought one from FoxtechFPV and have found it much less sensitive the 3DR ublox indoors, but able to obtain more satellites outside.  Previous discussions have talked about the configuration file for U-Centre. I have connected to U Centre and can talk to the GPS. Everytime I change the baud rate to 38400 and save the configuration and disconnect it, it reverts to 57600. I'm not sure if I am doing something wrong or it has no battery for flash.
    Is there a command string that APM and Pixhawk write to the compass to configure it?  As well, what is the setting to turn on all of the satellite networks for the M8N?
    Thanks,
    Joe
      By the way, the GPS driver is suppose to work at baud rates higher than 38400 although I have never tested that this works reliably.
    • The reason your config isn't saving on the m8n is because you are unable to write to the rom after changing the baud rate, since u-center will still be connected to the gps at the original baud rate.
      The way I do it, is make all of the config changes except baud rate, write the config to rom, then change the baud rate to 38400 in the gps config, then in u-center change the baud rate you're connected to the gps at to match. You will then be able to write the changes to the rom. You can see when you're connected in u-center when there's a green dot down the bottom somewhere that flashes when you bring up a new page in the config or try to write anything. When it's not connected, or has a baud rate mismatch, changing pages in the config doesn't make the dot flash.
      Hope that makes sense!
