ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • Hello
    A small task
    to use our experimental carrier is with pixhawk 3.2 RC12
    http://youtu.be/LcixgRRB4sU
    • Awesome flight test but where's the dog that goes with the leash? Are you planning to use the drone to walk the dog later?  LOL
  • Randy and All,
       On the Morning, I have test is Auto Spline Waypoint with 3.2-rc12 is very stable and perfect. And, I have show my video @ below.
  • Here is something that happen to me...
    On two different setups, one with genuine pixhawk and the other with a clone.
    Using teeny 3.1 on telemetry port 2 for datalink to Taranis on both setup
    after update from 3.15 to 3.2 RC12 on the genuine Pixhawk every thing is good.
    after update from 3.15 to 3.2 RC12 on the clone, unable to get data, no exchanges between teensy and clone. If revert to 3.15, all is back O.K.
    Thank you for any ideas and support with this
    and...  Keep the good work, it is greatly appreciated.
    Mario
    • Check your SR0, SR1 and SR2 parameters. They sometimes get messed up and receive 0 values at initialisation. Since I use minimosd I am familiar with changing them to suit miniosd needs, this is how I caught this.
      • Artem,
        Do you have the parameter list for the SR0, SR1, SR2?  I can't find them documented anywhere... I guessed and set SR2 all the same as SR1, which makes the minimosd happy but have no idea what these parameters actually are...  appreciate any docs you can point me to.
        Steve
        • Minimosd wiki, same settings for all three. This is what makes both my minimosd and teensy happy.
  • Randy / Developers, Absolutely amazing piece of software. Love the new capabilities.
    Despite excellent flying qualities, I noticed several odd things today. Keep in mind this is my first flight with anything newer than 3.1.5.
    Flying 3.2 RC12 with HKPilot 2.7
    Mission Planner 1.3.10 build 1.1.5369.11976
    Quad/450
    (I understand if i will not get a response for HK hardware, but i swear that i have several 3DR auto pilots, this just happened to be the copter i was willing to loose)
    I was switching quite frequently between STABILIZE, ALT HOLD, & POSITION with frequent take offs and landings to do some fine tuning on the PID's. At some point it became impossible to switch to POSITION mode. It was first noticed on the RC transmitter and i confirmed that the PWM was in the proper range for chan 5 out. I noticed that on the mission planner when i went to the "Initial Set up" page / "Flight Modes" the Flight Mode #4 was completly blank. I confirmed that chan 5 is 1588 PWM and Flight Mode #4 is green. I reset Flight Mode #4 to POSITION, with no luck. I am also unable to select POSITION from the Flight Data / ACTIONS page. I have attempted multiple reboots of the autopilot and GSC and have not been able to set POSITION Mode since.
    3701850816?profile=original
    I also ran into this problem on the CLI page. This was problem was present before i had the POSITION problems and i do not think is related, However i am unable to get Chip Logs, but i do have tlogs if interested.
    3701850938?profile=original
    • i would like to confirm this. upgrading from RC7/RC10 to RC12 there was no POSHOLD, DROID PLANNER also does not acknowledge Position. Hopefully tis can be a quick fix on both ends
