ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • Loiter and RTL want work correctly.
    I changed both GPS-Modules to 5Hz, but in loitermode it´s going crazy, the copter is hopping and everytime correcting with pitch and roll.
    RTL-Mode = no reaction.
    At this time i dont know what i can do....
    Please help me to check my logfile.
    2014-11-15 16-27-10.log
      Dominik,
      I had a look at your logs (sorry for the delay).
      I guess the issue is that it's wobbling a lot in roll and pitch during loiter.  It looks like the  HLD_LAT_P parameter is set to 4 but the default is 1.  If you return it to it's default I think it'll be ok.
      • Holy sh**.... I dont know why the Parameter jumped up to 4. I never changed it manually.
        I corrected the large compass params!
        This Weekend i´ll spend some time to test it again.
        And the winter is coming soon, i´ll correct the full build up and optimize some parts to reduce the vibrations.
        Randy? GREAT SUPPORT!!! Thanks for your answere ;-)
        Cheers
    • Nobody can help me? :(
      • 3 GPS/Compass related errors showed up in your logs.
        Event/Failsafe ERR found: GPS_GLITCH
        Compass Large compass off params (X:18.00, Y:60.00, Z:384.00) No MAG data, unable to test mag_field interference
        GPS GPS glitch errors found (1) Min satellites: 0, Max HDop: 1.6     I can't help you with configuring your GPS though.
        -Mike
  • @Terry: +1 here with APM. Very surprised about the "extra short" time given to do the live compass phase..? Mission Planner just stop and give values.. A bit scary not knowing if it was "too long" before or "too short" now?
    Just had a flight with 3.2 and RTL did the right thing so I only assume the compass was correctly setup?
    Didn't try with Pixhawk yet. Would be nice to know why only few points seems sufficient where 2000+ points (or as many s you had patience for) could be checked before?
    Henri
      Henry,
      Thanks for the report.
      After all the reports on this thread, Michael and I did a bunch of testing on the MP's compass calibration and found two problems, both of which are now fixed:
      1. the 2nd compass's offsets would become near zero if the calibration was run twice in a row
      2. the Auto-complete feature threshold was set too low which could lead to offsets being off a bit (in my tests on just one pixhawk I could get variations of about 6degrees).
      Michael/Craig say both of these issues have been fixed in the latest Beta so I highly recommend that everyone who is using the Beta, pushes the "Check for BETA Updates" button on the Help screen and if you saw a suspect compass calibration (i.e. it finished too quickly) please re-do the calibration.
      At the risk of sounding like I'm passing the buck, I want to point out that the compass calibration is completely within the mission planner, it's not directly related to AC3.2.
      • most excellent......
        thx for your efforts
        • Yes, Mission Planner 1.3.12 (i suppose this is the latest) has very nice compass calibration like the one in MP 1.3.10. I did 3 auto flights with compass calibration from MP1.3.12 with no issues.
  • Randy,
    After i've rebuild my hexa i did some testing with Autotune.
    Manually tuned i would go for this PID's
    D 0.008
    I 0.160
    P 0.18
    STB 9.3
    I've run Autotune more times and gettting always very high values, something like
    D 0.02 (for AC 3.15 i got 0.0085 and no oscillation)
    I 0.3 (for AC 3.15 i got 0.065 and no oscillation)
    P 0.3 (for AC 3.15 i got 0.065 and no oscillation)
    STB 13.5 (for AC 3.15 i got 11.2 and no oscillation)
    After some additional testing i've identify the D value 0.02 to be too high and responsable for the motor oscillation.
    please see the Log attached 2014-11-16 14-35-15.zip (includes short testing in stabilize after autotune)
    i''ve then decrease D until oscillation was gone and ended at 0.009. Please see second log 2014-11-16 15-31-11.zip
    for comparison.
    Can you give soime advice or discuss this with leonard ?
