ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
            • Hi,
              HDOP says nothing about the accuracy in case of having reflections or Multi-Path reception.
              HDOP is only based on the position of the satellites received which determines how accurately you can in theory calculate the position if and only if the received signal is perfect. HDOP is not impacted by reflections, but the GPS accuracy definitely is.
              The effect is the following:
              - HDOP bad means that: the GPS position estimate is likely to be bad since the received satellites are in a non-optimal position.
              - HDOP good means that: the position estimate can be good based on the satellites received if the signal is not disturbed in the atmosphere and not reflected of buildings etc. HDOP will not indicate this at all.
              So a low HDOP indication while being in a very urban area or inside a building means nothing. Indeed typically the estimated position will be wandering all over the place.
        • Bill, you're right. So my solution is to shield the GPS antenna directly from "low elevation sats" and multipath signals. Remember my yoghurt pot trick.
          Thomas, thank you for the ublox config, but..
          As a every year discussion I don't agree with enabling the signal correction via SBAS. In my opinion that makes sense for 24/7 applications or those who need high absolute position accuracy. For our copters, who fly around 30min, it could lead to damage due to GPS glitches.
          • Imagine you have a 3D fix+max. satcount and take off, GPS position is a bit "off" (but doesn't matter for 30min bcs it keeps that offset the hole flight).
          • Flying around some minutes and suddenly EGNOS or WAAS data are received.(Sometimes 5min are not enough)
          • The GPS algorithm uses these values and calculates a new "correct" position(but 10m away).
          • AC navigation controller says puh, I have to correct my position...and copter flys away.
          So I think we only need "relative position accuracy" where a bit off is accepted. I don't need to drop things on a 20cm target.
          Randy told us, the ublox config is being sent to GPS on each boot. Is this still the case? Does this config overide the SBAS settings? Sorry I didn't have had time to investigate whats going on during boot.
          • Admin
            @Christian,
            I think that you can change the Mask parameter, which is 5 deg presently, instead of shielding the antenna from "low elevation satellites".
            TCIII ArduRover2 Developer
            Christian,
                 Yes, the config is being sent to the ublox on each boot.  It doesn't send everything though and I had a look in the AP_GPS_UBLOX.cpp file to see what exactly it's sending but even for me that would take a bit of a review.  It also tries to turn off messages that it doesn't recognise.
            • Thanks Randy,
              with the help of that nice USB port I was able to connect and also booting up pixhawk at the same time. In Ucenter I recognized that the port was still set to SPI and also that the small lock was locked. I guess "you" didn't have a chance to change settings for the very first time. I set it to UART1 manually, unlocked the lock and safed settings. (Baudrate still at 9600)
              I disconnected every power source, reconnected, booted up pixhawk and tada your values had been sent. Now baudrate is at 38400 as expected. Also rate settings to 5hz.
              Could sb confirm this? pls make a backup of the settings so you could repeat that procedure.
          • Seems to depend on location. If its not turned off, I did not experience any bad habit because of activated SBAS (EGNOS ..3 Channels)@ center of Germany . (Max M8Q with small active patch) I additionally disabled QZSS @ GNSS Config.
            @Emin: Peter showed a direct log comparision at drones-discuss between Max M8Q and LEA 6H as well between Max M8Q and NEO M8N, quite impressive.
    • so,will you use two gps?
      • Emin,
        yes I'll give it a try. It's a pitty that Missionplanner can't display both GPS data yet. I'm courios of what will happen.
    • that is awesome :). where did you grab the  Ublox-Neo-M8N?
      edit: woops read up, i see it now  http://www.csgshop.com/product.php?id_product=173
