First af all I want to thank every contributor to the Arducopter project for their hard work and commitment.
A few months ago I got hooked to this project and first of all did a lot of reading.
Last month I started ordering the different parts and yesterday was D-day for me because I did my first test flight after some minor problem with bad contacts the IMU headers .
First of all, my setup
APM
IMU
Mikrokopter frame
KDA 20-22L motors
ESC's 30A
APC 10 x 4,7
DIY power distribution
Here are some photos of my quad.
Note, the ESC's will eventually be covered ;-)
Now for my problem: PID tuning!!!!!!
I calibrated everything according to the manuals, uploaded the alpha 1 firmware and used the standard PID values. I did a test flight in stable and + mode.
My observations:
-Front motor and rear motors tend to turn very late.
-Before lift of nose tends to go in the gound.
-When in the air quad tends to drift and yaw to the left
-At a certain height (1,5m) quad starts to oscilate in the role axes
Stable PID values are:
Roll: P=4; I=0,15, D=1,2
Pitch: P=4; I=0,15, D=1,2
Yaw: P=3; I=0,15, D=2,4
I've allready tried some minor changes in the PID values but this cost me some leafs of a plant in the living room. ;-)
I would try to change Roll P to a lower value (3) to minimize the oscilation
Any suggestions?
Concerning the front and back motor that don't start immidiantly.
I checked very closly and these motors do start just before left and righthave enough power to lift off.
The nodge that sometimes comes up in video 1 is due to a problem with right motor. I openened it, cleaned it and at the moment it doesn't do it any more.
As it is poring rain at the moment here I can't test outside. So I did some low level flying. Also didsome calibrationon the differnt axes and started changing D Value. Lower that is. Seems to be losing the wobble.
Thumbs crossed that tommorow will be beter weather.
Vincent
~Kaotic
There is nothing wrong with the hardware setup 'cause i have flown it with the gaui 330x brain and never had problems.
I have calibrated escs, configured correctly the configurator and have only two motors spinngng correctly.
The others two saty just still.
If I give the minimum power all 4 motors spin correctly. As soon as I increase power, two of the stop working completely....
Could it be relatedto the APM firmware problem? (brownout voltage too high)?
Best regards,
Emile
~Kaotic
I have the same frame. I tried KDA 20-22L and Turnigy 2217-20 with APC 10x4.7 propellers. It is very stable with Turnigy using default PIDs but unfortunately I could not find a stable interval with KDA. I belive KDA 20-22L does not enough power.
http://www.giantcod.co.uk/speed-controller-p-402443.html
what ESCs do you use?
