Good day guys !!
I feel the need to obtain the information from my PixHawk in my Graupner MZ-24 screen. I found
some threads talking about a change in arducopter firmware to run the telemetry, not good at messing original controller firmware.
Then I found an "adapter" that staff of the AutoQuad made to convert the MavLink in Hott telemetry.
I come here to share a few changes I made in the project Mav2Rott downloaded here: http://autoquad.org/software-downloads/?did=31.
This is an adaptation to send the telemetry PixHawk for Graupner Hott Protocol.
Is correct with some features:
Battery Voltage;
Altitude for barometer;
Satellite count Speed;
Flight Modes Current drawn by the motor;
Direction of the Head;
I am not able to make it work:
Correct display Latitude and Longitude;
Distance of Home;
Direction of Home;
If anyone can help thank you very much.
The project is attached to the topic. The connections are equal to the jd-ioboard. I am using an Arduino Pro Mini.
Mav2HoTT_NoLeds.zip
  • gr24
    Michel Kosloff said:
    I have positive report with MZ-24. Which receiver do you use?
    Please consult documentation here http://mediamax.pro/MAVLink2HoTT
    You shouldn't tune anything in FC. All tuning is done via HoTT text menu.
    hüseyin yıldız said:
    i have tried with mz24 but not succes.
    any configuration on pixhawk?
    it shows gps data but no other info?
  • Your idea is a good approach, maybe a little extended:
    If movement in air about <min> km/h and about <min> satellites show GPS direction else show compass yaw.
    This will avoid changing direction on copters with weak GPS signal when hovering (there is always statistical movement without useful direction vector).
    May show compass yaw when on ground / disarmed and GPS travel direction in air.
    Hannes said:
    Thank you, coordinates are now correct, perfect.
    The flight-direction may need some more thoughts and discussion.
  • I have positive report with MZ-24. Which receiver do you use?
  • May show compass yaw when on ground / disarmed and GPS travel direction in air.
  • Thank you, coordinates are now correct, perfect.
  • i have tried with mz24 but not succes.
  • Thank you for you testing.
    I set both fields in GPS message:
    flight_direction contains GPS course (not current yaw, but real movement direction form GPS)
    and
    angle_compass is set to current yaw.
    I don't know what RCs display both fields, but my MX-16 and MX-20 RCs do display flight_direction. I've got some reports of correct work of this code with MZ-24 RC, but I still don't know which data fields it does display. Regardless of display, RC logs all data to flash card, but I never used those logs in real life.
    I thought if flying copters it's better to show real movement direction as copter may fly any side ahead.
    If flying plane (code supports both) this is also informative as it shows real travel direction including wind influence.
    If this is critical I can make this parameter configurable via text menu.
    I renamed flight modes as you requested and modified coordinates calculations according to your example.
    I upload new HEX for you now, but I made it without testing as I have only my laptop with me now.
    Though I'd like to ask you do some testing and report results.
               Michel.
    MAVLink2HOTT-v1.4.1.hex
  • Loaded today MAVLink2Hott 1.4 into a pro mini board.
    It works great with my MC32 and GR-16.
    The first thing I noticed is that the GPS coordinates are not correct: Graupner Display shows coordinates in dd° mm.mmm' format.
    When you compare the position from missionplanner in dd.ddddd° format at this website: http://gpso.de/maps/ with position from transmitter display, you will notice different locations.
    You can find my conversion function https://github.com/j-lang/MAVLink2Hott/blob/master/Functions.ino from line 130.
    Which direction shows the "DIR:" field? My copter is oriented to north, missionplanner shows 11° and DIR: 196°? Home-direction shows 0 because copter is on ground.
    Thank you for making the interface configurable via textmode!
    Can you change old flightmode "hybrid" to new "position hold"?
  • Version 1.4 released. Many bugs fixed.
    Newer documentation will be available at http://mediamax.pro/MAVLink2HoTT/ in few days.
    MAVLink2HOTT-v1.4.hex
    MAVLink2HoTT
  • Current version uses 85% of code memory and 55% of RAM. I don't think integration with MINIMOSD is possible. May be with newer CPU.
DIY Robocars via Twitter
1 hour ago
RT @_JonMyer: 🚨Attention DeepRacer's including #UndergroundDeepRacer🚨 Check our our LIVE stream that including @IAM_dbro Take a few moments…
Aug 5
DIY Drones via Twitter
RT @MarvelmindMaxim: Extreme precision for 60 swarming robots. #marvelmind #autonomousrobotics #robotics #swarmrobotics #rtls #ips #indoor…
Aug 3
RT @MarvelmindMaxim: Precise (±2cm) tracking for racing boats and autonomous boats. Works outdoor and indoor. #autonomous #AutonomousVehic…
Aug 3
RT @MarvelmindMaxim: Helping PixHawk folks to fly autonomous quadcopters using PX4 and ArduPilot. https://marvelmind.com/drones/ Equally suitab…
Aug 3
RT @chr1sa: The @DIYRobocars @donkey_car virtual AI car race is starting in 15 minutes! Watch it live on Twitch https://www.twitch.tv/mossmann3333 htt…
Aug 1
RT @chr1sa: Don't miss our monthly @DIYRobocars @donkey_car virtual AI car race tomorrow at 10:00am PT live on Twitch. Head-to-head racing…
Jul 31
RT @sparkfun: Our completed tutorial on building an @NVIDIA Jetson Nano-powered @Sphero RVR gets your bot up and running via teleoperation…
Jul 30
RT @SmallpixelCar: Freeway test https://t.co/4V5tV9lhIP
Jul 29
Very small autonomous cars racing, thanks to an overhead camera: https://control.ee.ethz.ch/research/team-projects/autonomous-rc-car-racing.html
Jul 29
Jul 29
Jul 29
RT @chr1sa: Don't miss our virtual AI car race this Saturday! Real developers + virtual cars =🏎️🏎️🏎️ Head-to-head battles with thrills, sp…
Jul 28
Jul 27
RT @usashirou1: Jetson nano by Isaac Kaya #jetson https://t.co/Mu1N0CyQkN
Jul 23
RT @GPUsolution: JetRacer mady by Iflytek company #JetsonNANO #Nvidia https://t.co/MimTymIwge
Jul 23
