ArduCopter2 Trouble connecting
I have connected and uploaded the new code via mission planner. I have gone through the setup with the CLI and MP. When I slide the switch forward to the fly position and try to connect to the mission plannner it never connects even with gps lock? I've even tried to connect via Xbee's set at 56700, but nothing. All the lights are good "A" is solid green. I do NOT have it conneccted to the Rx or ESC does that matter? I'm trying to make sure everything is working first. 3690867425?profile=original
3690867458?profile=original
    Try connecting with the Mission Planner over the USB first. You need to tell the Mission Planner which PC serial port you're connecting from. Check your Windows Device Manager if you're not sure what port has been assigned to what.
