Ardupilot Crash - Help needed
Hi Guys,
We have been using Pixhawk in our fixed wings since a long time and have been quite successful with it so far. Today something strange happened:
We were tuning a new platform meant for aerial mapping. It was a bit windy day but manual take off went well and after trimming a the platform we switched to FBWA for finer tuning when suddenly the plane lost all the control and came down like a rock. It felt like it had no power and when it got inverted it could be recovered at all. We tried switching to manual mode but I dont think this was registered at all.
Following are the specs of the platforms:
3m span Glider
Hacker Motor
Castle Creations ESC
16000 mah 6S Tattu battery
Mauch Power Module
Hitech Servos
I am attaching the drive link below of the bin file and would be great if anyone could help us understand what went wrong.
https://drive.google.com/file/d/0B-wBxBwIyRqVeTNfRUs0QnFfZHc/view?usp=sharing
    • Hey Andre,
      Thankyou for your comment. The system was powered via the Mauch Power Module + Extra 5V supply from the ESCs (internal BEC).
      Do you suggest doing something more than this?
      -Pravin
      • Was the extra 5v (on servo rail) actually within the range of what Pixhawk could use ? (or was it higher?)  - you need to measure  to be sure.
        Also - you would need to verify that the power module actually supplied power, or else you could have been flying on servo rail power (possible to overload /or make overshoot - or by fed back by digital servos.)
        in any case, check power.
        • We checked by powering with both the power module and servo rail and pixhawk was getting powered from it independently.
          I do think a digital servo may have been the problem taking too much current at some point. I did have two Hitech Digital servos in Ailerons. However the voltage of the pixhawk has never gone below 4.8V as per the log.
          • That......
    • Great story. Thanks for sharing.
      If the Pixhawk lost power and flew away, then rebooted, how did it arm itself to be able to RTL again?
