Howdy,
I’m working on my third VTOL control arrangement (images below). The first two didn’t go so well:). Using off the shelf ‘damping’ gyros (E-flight G90 for yaw and Futaba GYA352 for pitch/roll) mixed together through Parallax Propeller boards I can just about fly this. I can hold it airborne in ground effect in my living room for about a minute. It should be a lot easier outside with low wind. My next step is to add 1 or 2 Hitachi H48C 3-Axis Accelerometers and maybe a LISY300 Gyroscope to determine and hold absolute pitch/roll orientation. If I can get that to work I’ll try to pull the G90 and GYA352. Finally add wings and a pivot mechanism then go fly.
Instead of a hodgepodge set of accelerometers I started to looking at off the shelf IMUs and landed here. A couple of questions:
- Does anyone think the ArduPilot Mega is capable is replacing my Parallax Propeller Board with this type of VTOL configuration? Keep in mind for the most basic case I have 4 channels in and 8 PWM mixed out.
- Anyone heard of someone interfacing the IMU “Shield” bit of the ArduPilot with a Propeller? Just in case the microcontroller bit makes me angry.
mVTOL_V3 – Current configuration. Using (4) Turnigy C5055-600 each with independent servo and (2) 5Ah 6s1p batteries.
mVTOL_V2 – Variable pitch motor for pitch was problematic due to thrust hysteresis around center. But probably could have been solved with a bit more determination.
Please note I’m just doing this for fun. But I would like my toy finished and flying soon.
hi all
actual arduplane 3.6 support quaid plane configurations with tilt motors
but not found docs how to configure tilt servo
i setup
Q_FRAME_CLASS,0 - quaid frame
Q_FRAME_TYPE,1 - x motors setup
Q_TILT_MASK,5 --my plane have 1 and 3 front motors tiltable 00000101B = 5
RC10_FUNCTION,41 --tilt servo at aux 2
RC10_MAX,1850
RC10_MIN,1050
problems
-i have no any signal at aux2 output
-tiltable motors do not start in plane stabilise or manual mode (only turns in qstabilize)
This may be of some interest...ArduPilot Mega seems to be working fine with his system:
http://www.gressaero.com/
nVader 600 Bicopter with ArduPilot Mega Autopilot
This is cool too:
Wow! No replies? No ‘maybe’ or ‘good luck with that’? Did I ask this question in the wrong forum category?
…maybe my VTOL is too ugly and you guys are still laughing too hard to type:)
I guess someone needs to be first. I’ll get one and see what happens. It’ll probably take me a few weeks before I report back. Hopefully there will not be too much screaming, running and bloodshed …this time.
