ArduPlane 2.73 released
I've just released ArduPlane 2.73 as a bug fix release for several important bugs in 2.72
The main reasons for this release are:
  • fixed a noise and scaling problem with airspeed sensors
  • fixed a potential flyaway problem with the L1 navigation controller
  • improved handling of poor GPS velocity for attitude correction
This release does not contain the new attitude controllers that I previously said would be in 2.73. Paul and I decided that it would be better to hold those over to the next release, and get this release out with just the above critical bug fixes.
The airspeed problem stemmed from a changed introduced in 2.72 to make ArduPlane automatically scale analog inputs with board voltage. That change was good for voltage and current sensing, but it added a lot of noise to airspeed sensing as the 3DR airspeed sensor is ratiometric (the sensor output scales with the supply voltage). The fix was to add support for ratiometric analog inputs. This release also fixes a bug in the airspeed ratio handling. To confirm the fix I have been driving around in my car with an APM2 and PX4 logging airspeed and GPS speed - that test confirmed the airspeed sensing is now accurate.
The flyaway bug in L1 was caused by an unusual situation where the previous waypoint was equal to the next waypoint, which can happen when a mission is interrupted and restarted. The L1 controller would then level the wings and fly straight ahead until the operator intervened. The bug fix was to make the L1 controller detect this situation and track directly to the next waypoint. I don't think many users would have seen this bug, but it definitely could happen and warranted a bug fix release.
The GPS handling bug was related to the MTK GPS, which can be very slow to report loss of GPS lock, which could lead to very poor attitude from DCM and even a crash if the plane tries to turn while the GPS is reporting incorrect velocity information. The fix was to watch the satellite count, and stop using the GPS velocity for accelerometer correction when it had less than 6 satellites. This is selectable with the new AHRS_GPS_MINSATS option.
Other changes
While this release doesn't have the new attitude controllers I decided to leave in some other smaller changes that have been made since the 2.72 release that I consider to be low risk, including:
  • fix the PX4 barometer driver to run at full rate
  • fixed handling of a saturated compass on PX4
  • added COMPASS_ORIENT option to support external compasses
  • fixed the compass in HIL simulation
  • added GCS messages to flash logs
  • allow 3D accel calibration over MAVLink
  • Added new ELEVON_OUTPUT option
  • removed MANUAL_LEVEL option (manual level is now always on)
  • improved pitch handling when inverted
Of these, perhaps the most useful is the ELEVON_OUTPUT option. That makes it possible to setup your transmitter with normal aileron/elevator and get the APM to do a software elevon mixer on output. That gives better control in FBWA mode than the previous elevon options.
I recommend that all users of 2.72 upgrade to 2.73. Happy flying!
Cheers, Tridge
  • Tridge,
    I had a couple of flyaways with 2.72. It happened when I restarted a mission. As you said, wings-level flyaway. I had to create a new mission and upload it before the plane would respond.
    Thanks for the fix.
  • I get this error when trying to use GridV2 on MP 1.2.50.
    Also when I check the "Area" under Auto WP, it is showing "Area:-9548.23543215 m2".
    The error mentions an index that cannot be negative. Is this the problem?
    3692715819?profile=original
  • Hi Andrew,
    Thank you for the fixes.
    I give it a try in Xplane9 in HIL mode and checked the modes however the HUD display shows inconsistent angles.
    Actually it starts with around 90 degree positive pitch and later on all of the angles go crazy. I can only fly with manual mode.
    My configuration is: Xplane9, Missinon Planner 1.2.50, APM2.5, Turnigy 9X Tx/Rx
    I also checked my configuration with:
    Arduplane 2.72 behaves the same
    Arduplane 2.69 and 2.71 works fine
    Thanks.
  • Andrew, when are you going to enable gimbal control? And GRIDv2 not filling in the polygon. You had to have seen my many posts about this...
    It seems like 90% of people just use Arduplane for flying waypoints. But those wanting to map are plagued with bugs and no help. We are the minority but we still want a working product. I cant even use this for mapping because of the lack of gimbal control through DO commands, and the problem with GRIDv2, which I need for camera triggers...
     I don't understand how to beg harder than I already have for some assistance.
    http://www.diydrones.com/forum/topics/grid-v2-does-not-work-develop...
    http://www.diydrones.com/forum/topics/do-command-not-working-what-a...
    Thanks, Tridge. Looking forward to trying out the new Elevon controller.
  • Great work.. I will be giving it a try this week end in my Ardu-Raven sUAS. When do you foresee the release of the new attitude controller. I am looking forward to this next feature to make setting up an airframe simpler.
