Posted by Ahmed Rehan on October 12, 2014 at 2:24am
ArduPlane 3.1.1 not working proper on flying wing any body else facing problem as soon as switch on to fbwb or auto mode it nose dive and roll on one side.
I am not using airspeed sensor and it is disabled min air speed is well above stall speed. Airframe is custom cnc cut 3 part flying wing 2M span will post photos later.
Adam Kroll > Ahmed RehanOctober 13, 2014 at 12:38am
Its 99.99% likely that Tridges recommendations will solve your problem.
I recently bought pixhawk and the last firmware version I used until recently was 2.67, since then a new method of elevon mixing had been introduced, which had me stumped for a day until I found this page
Make sure to read it carefully in particular the chapter - New style elevon mixing EEPROM setup (ELEVON_OUTPUT option)
Ahmed Rehan > Adam KrollOctober 13, 2014 at 7:31am
yes i already checked this and tested using elevon_output option in manual mode it is ok. i will do next flight after recalibration and will update.
Ahmed Rehan > Ahmed RehanOctober 14, 2014 at 4:33am
Thanks to every body specially Tridge / Gary
Just Tested with new calibration worked perfect tuned with auto tune. tested FBW_A and auto mode also worked perfect. The P gains were too low as default . will test auto takeoff and land and will update.
Ahmed
Ahmed Rehan > Ahmed RehanOctober 15, 2014 at 6:04am
Today Auto takeoff worked perfect will try auto landing in next flight any suggestions on approach of autolanding height and distances.
One thing to understand that may help you with the setup is that when you enable ELEVON_OUTPUT that is exactly the same as installing a hardware elevon mixer in your plane on the elevator/aileron channels. So all of the flight control algorithms, stability etc is the same on a flying wing as any other plane.
Cheers, Tridge
Ahmed Rehan > Andrew TridgellNovember 5, 2014 at 4:29am
Hi Tridgell / Gary
If motor stops and plane is in auto mode loitering over head will it decent in glide mode or try to give elevator to maintain altitude . As in my last flight it nose dived after motor stops on low voltage.
http://plane.ardupilot.com/wiki/arduplane-setup/first-time-apm-setu...
Ahmed
Ahmed, Tridge has responded, it is a setup problem please undertake the steps he has advised.
Gary / Tridge one thing i cant understand it flew one mission with the same setting ok navigating all waypoints and then started orbiting over head.
Hi Ahmed,
Do you have the logs of that successful flight?
Cheers, Tridge
Hi Tridgell / Gary
1
2
3
of 3 Next
