Hi everyone,
I'm new to these sort of projects, and I'm trying to prepare all the components I need to build a hexacopter. I'm looking to buy the jD-Simplex Hexa (RTF) from jDrones, with the upgraded motors, ESCs, and the 12x45 props. I'm also planning on purchasing the radio set with it. However, I'm in a dilemma about the battery I should get and what the flight time will be. I've read almost everything I can about how to select a battery and how to calculate the flight time.
With the upgraded motors and ESCs, I'm thinking I need a 8000 mAh 3S1P 30C battery, because 8 Ah * 30C = 240 A, and the ESCs run on 30 A (so 30*6=180). Can someone clarify this selection for me?
Also, if I calculated correctly, this copter at 75% throttle will have about 4.5 minutes of flight (with the 8000 mAh battery). Does anyone that has experience with this drone have a longer flight time than that?
Thanks so much,
Kate
Very hard to beat the Quanum Nova for bang for buck for a first outing, you willalso be getting used to the GCS and APM world
Does this allow any sort of programming modification on the APM with arduino?
Thank you, I'll look into it!!
for 1245 props, you can use 4s battery to increase endurance
Sounds awesome, I'll look into it. Thanks, Ye!
Good to know. I'm getting a lot more encouragement towards buying a quad than a hexa. Thanks!
Are you completely new to multi-rotor craft? Have you flown any kind of rc helicopter before? If you are new, just a word to the wise. Build something smaller and cheaper to cut your teeth on. It's amazing how easy it is to crash on your first flight, all it takes is a bit of mis tuning, mis configuration, a small mistake somewhere, an unexpected component failure, inexperience with helicopter/multi-rotor flight.. and your $900+ hexa would turn into a very expensive bonfire on the ground. I absolutely don't want to discourage you, but do consider a smaller much cheaper build to make your first experiences on. You can get a multi-rotor in the air for less than $100 (excluding flight controller/GPS and remote) and make some great learning experiences without the pain of seeing that beauty come crashing down.
All this assumes you are truly new to the hobby and I don't mean to patronise. Anyway, enjoy and good luck, you're in for what can be a very fun and rewarding learning experience.
Felixrising,
I appreciate your concern as I am new to copters in general. However, I'm an intern at the company I work for and this is my summer project, and my mentors prefer a hexa right now. I'm probably going to ask them to buy me a small quad with a lot of durability first to practice with before trying to fly the hexa. Although, I am hearing a lot about how quads are generally more efficient than hexas, so I might try talking them into that instead.
Thanks for the advice!
Will,
Getting the jDrones hex RTF is pretty much my plan, thanks for letting me know that it's a pretty solid path for my first time. I looked into the Pixhawk but it doesn't seem to have much programming flexibility? I liked the APM because I can go in there and change the code if I want. (btw, I'm not happy about Stargate being gone either).
Thanks!!
That's a great news :) more girls here, try FPV is just amazing :).
I have to put a profile photo :)
2
3
4
5
6
of 6 Next
