Hi there ,
I've attached the compass to the quad as the image below show (APM points forwards - between yellow arms). and the compass is Rotation_Roll_180.
When I'm calibrating the compass I keep getting reversed results (North shows South).
I've tried rotation none , yaw 180 , rotation_pitch_180 without luck.
1. Does this affect loiter mode ? Alt hold works fine , loiter and RTL don't work well , quad drift and fly somewhere it shouldnt.
2. What can I do in order to get good results from compass ?
Attached image how I mount my Ublox.
                  • u can do calibration inside but to test feature related to GPS u need to place the quad outside....
                • How I check sensors calibrated ?
                  I did compass calibration , radio calibration.
                  Just tested , I think loiter was ok - It lost some ALT and made small crush on ground.
                  LTR didn't work.. quad ascended and flew away from "home". I cut the throttle and it crushed... now I'm looking for some spare parts (my GPS cable is torn.. no idea where to get replacement)
                  https://www.youtube.com/watch?v=uwJ0410yPm4
                  • Sorry about that Eran. Steep learning curve here. You will get the hang of it. I recommend that you get comfortable flying in stabilize before testing any GPS functions. Stabilize is really your manual failsafe. anytime my quad misbehaves when flying with GPS (loiter, RTL, auto), I can quickly switch it back to stabilize and bring it home, assuming i still have line of sight.
                  • from APM mission planner teminal tab u can check the sensors by typing simple commands.....connect and type help u can see several options... to stabilize the quad first try position hold because it is a semi autonomus mode... u can control the throttle at that moment... after successful position hold may try loiter.. If you compass and GPS is working proprly then RTL should work...
  • The compass right now is facing that the YELLOW legs is the direction of your quad, so try Yaw 90 Yaw 145 , Yaw 180 etc.
    Only use the YAW ones not roll or pitch.
    • After each YAW do I need to do calibration again ?
  • the roations_roll_180 is (semi) specific to the 3DR GPS/compass module.
    it appears that your compass chip is on top of your GPS/compass board - in which case, you would not want roll_180. Usually the z-axis is directed out the top of the chip.
    The other possibility is electro-magnetic noise affecting your compass readings. you may need to elevate your compass further away from your power distribution.
    • My power distribution is below the APM (I use QBrain) I don't believe it affect the Compass (see image).
      How do I know what is the correct orientation of the compass to mount ?
      • On my copter, my GPS/compass is 6/7 cm above my power distribution and is shielded by a ground plane directly underneath the GPS/compass.
