I've got a 3DR Hex with 850KV motors 10" props and I'm using a 35C battery.
The ESC's were calibrated.
The TX is a Walkera Devention 7 and it's been calibrated using MP.
I'm running the latest APM2.5 firmware and Mission Planner version 1.2.52 mav 1.0
The PIDs I'm using right now are the defaults that come with the Hex firmware.
I've got everything hooked up and it flies. Pitch, Roll and Yaw are great. In Stabilize mode, it stays nice and level, it's responsive and very easy to control.
But throttle is another matter. In Stabilize mode, the hex bobs up and down a lot and I need to constantly adjust the throttle stick to keep it reasonably level.
Today I was trying to put it into a hover. It will go up or down, but won't sit in one spot.
My transmitter has a digital readout showing the throttle setting from 0% to 100%.. At 27% the hex will sink, at about 28% it will either rise or sink, and at 29 percent, it will rise. I spent 13 minutes trying to get a reasonably stable hover and I couldn't.
I'm wondering if there's a PID that needs to be tweaked in order to level out the throttle?
bro im always ever so slightly feathering my throttle to keep it dead level in stabilize, its defiantly envorimentals that will effect a perfect hover, every so often when the conditions are right it will hover in stabilize hands off, throw it into loiter and watch it hold alt nicely.
