Configuring Futaba R6208SB for mode B
Hi there,
I have a Futaba R6208SB connected to a pixhawk through SBUS and all work great.
I would like to configure the 6208 for mode B usage, where I can get another 8 channels(9-16) through the analogue ports of the receiver. I do power the receiver while pressing the Link button, I get the red and green led to flash simultaneously, power it off and on again, set the 14 SG channel9 to a switch, but no effect whatsoever.
Han anyone managed to do this? I have included the Futaba manual in thiw message.
r6208sb-manual.pdf
Cheers
Spyros
  • You plug the Red jumper plug on top of 6208 and follow the instruction on 6208 manual, after you get it in mode B and powered down remove the red jumper plug.
    You said you plug the 6208 into the Sbus connection on the Pixhawk, I thought it was you plug the 6208 into the RC port on Pixhawk.
    • Hi there,
      Thanks for your reply. Have you tried this with Pixhawk and it worked?
      I will use the jumper as I did not use it before. Should get 16 channels?
      • I'm in the process of building up Tarot 680 Pro Hexicopter, I have not got the Pixhawk wired up yet.
        I have the R6208Sb working in the mode "B" on a quadcopter with a ZeroUAV Gemini Controller.
        I'm not quite sure if you can hook to the RC port of Pixhawk with pure Sbus, or you will have to use a Sbus to PPM converter.
        Some thing I did find out about the PixHawk is you must use a ESC that has the 5V Pos+ wire to power the Servo Rail,
        I purchased six OPTO ESC's and they do not have the 5V POS+ wire, only a Signal, Ground wire, so I will have to use a UBEC to power the Pixhawk 8 Servo Rails.
