Confusion with Pixhawk Servo Rail
Hello everyone!
This is probably a stupid question, but I am still confused regarding the Pixhawk servo rail. The ardupilot website claims that the Pixhawk does not supply power to the servo rail. But so far the only thing plugged into my Pixhawk's servo rails are the servos themselves, and they seem to be getting power just fine (I even flew the plane a couple of times). Why does everyone say I need to supply a separate power supply to the servo rail when my plane seems to fly perfectly fine without one? I am still confused, and I was hoping someone could please explain it to me.
-Andrew
  • This reply was deleted.
    • he did wrote "But so far the only thing plugged into my Pixhawk's servo rails are the servos"  - so it's very strange.
        • Based on the information, (nothing else than servos) - I guess it may be a bad clone - it's hard to even call it a clone, maybe bad imitatio would be more likely.
          OpenPilot community discovered recently garbage like this: https://forums.openpilot.org/topic/57613-so-you-bought-the-clone-fl...
          I've seen myself low voltage switch mode power supply clones assembled with random capacitors of similar physical  size (higher voltage, lower capacitance), instead of the correct capacitors.
          So when it comes to lookalike-garbage in the world of electronics, even components are cheap, nothing surprises me. :)
          Andrew A - where did you buy the Pixhawk, - and - if you vought it anywhere else than 3DR , and you did not use ESC or BEC,  - could you please open it and post close up photos of the electronics inside ?- I could quickly compare it to the original schematics.
          • Dear all,
            Thanks for the responses! Sorry for the confusion and the late response, but I have attached a picture of what I am talking about. As you can see, I have only 5 (five) different connectors plugged into the servo rail. They are:
            1) Futaba receiver
            2) Ailerons
            3) Rudder
            4) Elevator
            5) Throttle
            Nothing else is plugged in (i.e. "no power"). However, all of these things work and I have flown my plane as is with no problems. I am not sure if I am understanding what is really going on...Can someone please explain why I am able to still fly my plane as is without plugging in a separate BEC directly to the servo rail and without including a Zener Diode?
            https://storage.ning.com/topology/rest/1.0/file/get/3702843688?profile=original
            • You say Bormatec : which make mostly small electric planes, in you Throttle control an actual servo servo (for a gas/nitro engine)  - or is that an ESC for electric motor ?
              If you have an ESC - then it's most likely to have an "BEC" in it, to verify ,disconnect 5 and servos should not work.
              • Hey there!
                Just wanted to let you know that you were correct. I disconnected the ESC/Throttle connection on the servo rail and I had no power.
                Mystery solved! Thanks for your help!
            • And no, this is not a knock-off or a fake Pixhawk.
  • I do not have the complete schematic in head, but it does not supply power, and I am not even sure such failure its possible, but there's a redundant power chip that may be fried, if you have an actual Pixhawk not a cheesy copy ?
