Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Erwin,
I am glad you asked :)
AUTOTUNE_AXES controls which axis is tuned.
1 is roll
2 is pitch
4 is yaw
So then you add them if you want to do multiple axis so
3 is roll and pitch
7 is roll, pitch and yaw.
So do one axis then put a new battery in and do the next axis.
Let us know how you go.
Leonard
Hi Leonard,
So I attempted to tune today my Y6B and ran out of battery as well. So back to re-reading this post. So if I understand you right, multiple axis tune is adding any sequence of 1, 2, or 4 to get a total for what you want the copter to tune to.
Example:
1 + 2 = 3 So 3 is what I put into AUTOTUNE_AXES to get it to tune just Roll and Pitch
2 + 4 = 6 Would be to tune Pitch and Yaw only
So I tried to enter in a single axis tune such as Roll (1) but the mission planner stated not a valid number. However after entering 2 and 4 and then back to 1, the mission planner didn't balk at me for enter 1 into it.
At this point I disconnected power to Y6B and re-powered and connected to find I could not repeat the error message. Hmmmm. Gremlins.
Thanks for explaining the Autotune configuration settings. This will help me tremendously to tune my Y6B using the 6000 mah batteries I have.
So cool!
I set my Autotune_Axes to 1 and Roll was successful. Tomorrow (weather permitting) I will plan to perform Pitch test only. Attached is my logged flight for anyone to review.
Humidity = 55%
Winds = Calm
On a separate note. I noticed on all my test flights that the GPS status indicated in the AutoAnalysis stated FAILED Satellite min 0.
However, when I reviewed my logs, they showed both GPS units (NEO-M8N (P) and LEA-6H (S) held satisfactory number of satellites and both had low HDOPS (below 2.0) for majority of flight. However it FAIL due to HDOP hitting above 2.0.
So the question is, is it truly a FAIL as most of the flight it stayed low? I suppose if it goes up at anytime during the flight it's considered a FAIL for GPS status. Guess I'm glad I wasn't in Auto.
Log File C:/Users/Doug/Documents/ArduCopter/UAV Logs/HEXAROTOR/1/2015-04-15 19-31-14.log
Size (kb) 20005.1103515625
No of lines 269057
Duration 3 days, 23:45:27
Vehicletype APM:Copter
Firmware Version V3.3-rc1
Firmware Hash 5a4039d9
Hardware Type
Free Mem 0
Skipped Lines 1
Test: Autotune = NA -
Test: Balance/Twist = NA -
Test: Brownout = GOOD -
Test: Compass = GOOD - mag_field interference within limits (16.48%)
Max mag field length (564.60) > recommended (550.00)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERR found: FS_BATT
Test: GPS = FAIL - Min satellites: 0, Max HDop: 2.5
Test: IMU Mismatch = GOOD - (Mismatch: 0.36, WARN: 0.75, FAIL: 1.50)
Test: Parameters = GOOD -
Test: PM = NA -
Test: Pitch/Roll = NA -
Test: Thrust = NA -
Test: VCC = GOOD -
2015-04-15 19-31-14.zip
"support do-set-home command (allows return-to-me and locked home position once GCS enhancements are completed)"
Can somebody provide some information on this specific feature above (10.a)? Is this implemented and its currently usable? If not, then when will it be available?
Evan
Simple test flight with autotune on Y6B - tuned parameters are not usable - reverted to manually tuned.
What is changed by Autotune_aggr and Autotune_Axes? What are recommended values?
2015-04-14 10-23-03.zip
Hi Hubertus,
In exactly what way is it un usable?
Autotune_aggr is a parameter that sort of defines the noise rejection of the autotune. It should have been 0.1. Autotune_Axes is a bit mask to define what axis will be tuned. 1 is Roll, 2 is Pitch, 4 is Yaw, 3 is Roll and Ptich ect ect.
You have the same a similar problem I am seeing with others (but not enough to stop you getting what looks like a reasonable tune) and I hope the next release will fix this.
Leonardt,
tried again flying with the autotune parameters - it´s flyable, but there is some overshoot and oscillations in roll. Rate P/I pitch is out of range according to MP - is this a problem? Response in pitch axis is quite good, so perhaps i should leave it to the tuned params.
Hi Hubertus,
Oscillations is definitely bad. But it is strange as tuned pids seem to be more conservative than your original pids.
If you could try the autotune in the next release for me I would really appreciate it!!
wow - thank you very much to all the developers!
Thanks Randy. My 4 Year old Daughter is into everything. Have had to lapse a little with playing the devs builds in the park. Have a pix and am looking on adding a second GPS. Maybe the Neo 7 as a redundant backup? Humm..
439
440
441
442
443
of 449 Next
