Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Thanks for the response and hard work put in by you guys into the community.
  • Hi there,
    Im trying to add px4flow(Lucas-Kanade method custom firmware) to pixhawk(3.3rc1) I think, Its work :)
    I have two question about that;
    1) Can I use Mission Plannner's user items "opt_m_x" and "opt_m_y" for optical flow checking?
    2) Which flight mode support optical flow? loiter, poshold, althold?
    • Hi guys,
      I use px4flow with this firmware (http://ardupilot.com/downloads/?did=118) to pixhawk(AC 3.3 rc1) by i2c.
      But it doesn't work. opt_m_x and opt_m_y are always zero.
      Did i miss something?
      The i2c address should be changed?
      sorry for my English.
      • can you try  power up by USB first.
      @Alp,
      Yes, optical flow should work although some more changes are coming to make it more reliable.  It was demonstrated at NAB with the solo.. it's all the same code.
      Only Loiter uses optical flow at the moment but that was a specfiic choice only because it's very new functionality  I expect we will extend it to other flight modes like RTL in the future (it's very easy to extend to other flight modes).
      Yes, I think the opt_m_x, y should show the raw output of the sensor.
      • Hi there,
        My question:
        1.Use USB connect PIX : I can in Mission Plannner's user items "opt_m_x" and "opt_m_y" for optical flow .
        2.Use Battery powered : Can't in  Mission Plannner's user items "opt_m_x" and "opt_m_y" for optical flow.
          But only reset PIX . I can in  Mission Plannner's user items "opt_m_x" and "opt_m_y" for optical flow.
  • I am waiting for the uploading the 3.3 rc 1 from the MP. WHEN is this ready?
      @heliroberto,
      It's there, just click the beta firmware's link on the MP's install firmware screen.
      • Hi Randy, when I look at beta firmware´s in MP than I see only the 3.2 !!!
          Yes, I also see V3.3-rc1.  Maybe try updating your version of mission planner.  Also you must be using a Pixhawk but that shouldn't matter because the MP doesn't know what board you have when it's not connected.
