Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Also, here is some description: http://copter.ardupilot.com/wiki/configuration/ekf-inav-failsafe/
But, I did not fly, I just armed on ground and immediately I get error. This is weird.
Flashing red and yellow with rising tone: EKF or Inertial Nav failure - http://copter.ardupilot.com/wiki/common-autopilots/common-pixhawk-o...
This is ok, but WHY? Why I get error on startup?
Hello Randy!
Just kindly wanted to ask if you are developing some features for the epm from nicadrone? I just ordered one and I think it has a huge potential.
Thank you so much to all you developers who are working so hard, you truly amaze me everytime you release an update!
Have a nice day!
Autotune again
below the results of autotune - just R/P - with my Y6B with large props (15").
Stability / response is GREAT!
Especially fast descend, what was a really problem before, now works nearly perfect.
Great work!
2015-04-17 08-56-15.zip
I wonder if the Pixhawk 2(what is difference to Pix1?)Linux computers and gimbal control etc, from the Solo will also be available for DIY in a frame of our choice?
The spec's look very similar to the Pixhawk Firecape - I wonder if its an evolution of that?
https://erlerobotics.com/blog/product/pixhawk-fire-cape/
Maybe you can also add what was suggested by our fellow member here before, a 2 stage fail safe for the battery. Is it possible?
The scenario is when the low voltage is triggered, RTL will activate, however, if the UAV cannot make it home with its remaining battery, the second fail safe will activate which will cause the UAV to LAND.
Hopefully it can avoid causing damage to the UAV nor to anybody as it will not fall like a rockf from the sky since it will gradually land.
Thanks in advance!
It's on the to-do list here. Just a matter of a developer picking it up and implementing it but it's hard to make promises when that might happen.
Thanks. I'm happy with the thousands of features Arducopter has now. It just amazes me how much work you and the team have done. Huge congrats to you all. I hope that some day I get to buy you a beer or two or three...
Darrell,
Thanks for that.
Yes, the distance limited by remaining battery is a really great feature. I don't think it'll make AC3.3 but I'll go out on a ledge and say it'll very likely make AC3.4.
