Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
            • Is there any best way to approach arming from a rocking boat now? Or will it still get its lean on?
      • On an inclined surface takes off without problem, only be attention, perhaps takes off from one side but flyes, many times I plug and armed on inclined surfaces. (APM 3.2.1. but I suppose is the same for this item)
    • I believe it happens at both times.  It calibrates on power-up, and then it re-calibrates on arming.
      • Sorry, this is wrong.  Sloppy reading on my part.  Emin was asking about accels, I read gyros.
        The gyros calibrate on power up, and again on arming.
      • Is the red/blue lights when arming doing a gyro or accel calibration (or both)?
    • As far as I Know it is after you connect the battery and it will flash red/blue that the calibration happens.
      From: http://copter.ardupilot.com/wiki/flying-arducopter/arming_the_motors/
      Arming the motors
      Before arming the motors, make sure all people and objects are clear of the propellers. Then do the following:
      1. Turn on your transmitter
      2. Plug in your LiPo battery.  The red and blue lights should flash for a few seconds as the gyros are calibrated (do not move the copter)
  • Permalink Reply by Randy 1 hour ago
    I've confirmed there's an issue with the vehicle's home location not being reliably set to the arming location but instead it's being set to where the vehicle first gets GPS lock or where it was last disarmed.
    Michael first reported the issue back on Apr 17th but I couldn't reproduce it.  I've reproduced it now and we hope to fix included in this weekend's -rc2.  The cause is a little complex and is captured in this issue but in any case
    I don't think it's particularly dangerous, it's more annoying if you tend to plug in the battery at a different place than you take-off.
    Sorry Michael for not catching the issue when you first reported it.
    • pg. no.20
  • Sad to apm2。
