Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Ok so I should be able to start in Stabilize as I did. I have tried to enable the autotune much higher but most of the times it descends to below 1 meter.
This time I was at least 3 meters above the ground before I enabled it how high should I be?
Did a new Autotune test, I had it in Althold even though it's not necessary, it didn't descend as before after enablign Autotune but unfortunately it ended in a crash.
I think though that the crash could have been due to a propeller that loosened midair. One propeller was a couple of meters away from the quad while the other three that loosened during the crash were quite near.
I've attached the log from this flight, didn't find anything noteworthy in them myself.
44.BIN
Anyone that could have a look at my logs and see if there is anything strange in them?
I hope to have the quad up and flying later this week so I can continue to test rc3 but would feel safer if anyone checked my logs if there is anything there that points out the cause of my crash.
Note to one self: Remember so set it in AltHold before atempting to autotune ;-)
Will do a new test tomorrow.
I flashed my Pixhawk to 3.3rc2 a few days ago. I have test flown it twice and in calm air, it works fine in stabilize, Alt-hold, and Position Hold. I intended to do an Autotune, set up a switch on channel 8.
however when I tried to engage it, nothing happened. I later saw that if there is any trim set, that it won't go into the auto tune.
Since then is has been too windy to try auto-tune.
In calm air, it flies well, but in a wind, it tends to go into a slow wobble when hovering, but in forward flight seems pretty stabile
As for my Gimble, I use a Tarot and I had to set MNT-Type to 1, because my previously set up pitch control on rc9 wasn't working..
That is working fine now, but I seem to have lost MAVLink on my Minim-OSD, I get Zeros on all telemetry in the OSD
It seems like a few revs back, I had to do some changes regarding SR0 or SR1 or something, to re-enable MinimOSD. Can any one shed light on what could be happening with MinimOSD, anyone else having this problem
RE
Never mind, I got the MinimOSD working again. The fix was to go into Mission Planner , into optional hardware and tell it that I was using OSD.
Then I rebooted it that the data was being received again in MinimOSD.
Got a strange error: PreArm need 3D fix when ground station shows 3D fix, gps status:3, gpshdop:1.7, satcount 12
And it arms in 3.2 with no problem
@ Dev team,
RC Inputs. Is there away to using channels RC13-16? The Taranis (and many others) has loads of switches, especially with the 6 position mod and I would like to add just a couple more switch options.
Cheers, Mike
Mike,
There's no way to use channels above 12 I'm afraid... but with this new release we've just expanded the aux switches so they can be assigned to ch7~ch12 (instead of just ch7/ch8). Do we really need more than 6 auxiliary switches? At some point I think we should instead make all these aux features available through the GCS which has a much richer interface and doesn't require any set-up by the user.
413
414
415
416
417
of 449 Next
