Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Paul,
I've torn down my rolling spider.
It seems that Parrot's using kind of ARM Cortex-A9 combing a on chip M0 mirco-controller.
For a 40 grams quad, it carries on board sonar together with barometer, the camera is kind of tiny cell-phone type.
All the on-board parts are highly integrated and its performance is really impressive.
3DR really need that tech to be competitive to Parrot and DJI, i'll keep my attention to see if I could help.
Zhang
Yes, open field with clear view. My first flight (first battery) was absolutely fine at the same spot then replaced the battery and got this error. I will set the logging and send it if it reoccurs.
Thanks,
Robert
Robert,
Thanks for the report.
This is a fairly common issue people are hitting with AC3.3. It's the EKF that's not happy probably because the GPS velocities are jumping around. We're going to add some better reporting of this into AC3.3-rc4.
Well my experience with new 3.3-rc3 firmware is somewhat strange. I lost MAVLINK communication completely. I cannot connect to Pixhawk either using USB cable nor telemetry with the latest MP. When I flash 3.2.1 stable firmware, all works fine. When I flash 3.3-rc3, communication is lost using the same settings. Can anyone confirm the same problem please ?
I had the same problem until I loaded the MP beta version.
Oh will try tomorrow then. Thanks for a tip.
Unfortunatelly MP 1.3.25.2 does not fix the problem for me. Sad.. I cannot use new APM firmware on Pixhawk now.. How can this be possible ? Noone else reporting the same problem ?
works now finally.. just uploaded other FW, then back this new APM beta and it works.. strange though..
Michael,
Sorry for the troubles. So the issue will likely be related to the "Serial Manager" changes. These allow moving around what each of the serial ports are used for by changing the SERIAL*_PROTOCOL parameters. They should default to "1" for those channels that will be attached to radios. There's also some new SERIAL*_BAUD parameters as well that allow changing the baud rate of each port.
So I'm not sure exactly which parameter was wrong but I suspect that by loading another vehicle firmware all the parameters were wiped out and reset to the factory defaults whichever one was wrong. By the way, there's a button on the MP's full param list which can more directly reset the parameters to the factory defaults.
Is there any reason why the multicopter descends quite low when I start Autotune? It did it with RC1 and now the same thing with RC3 I I raise the throttle it will ascend but really slowly.
Tried an autotune today even though there were some wind and when I repositioned the quad it descended even more and that didn't really work out to well ;-) Nothing is broken so I'll be able to do a new test but is it supposed to descend when I enable the autotune like that?
https://www.youtube.com/watch?v=2uWQyOFsJf0
