Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Hi David,
      Sorry for the slow response.
      This looks like a pretty clear loss of a motor. This is the first time I have ever seen a motor lost during autotune. Normally the loss happens after the twitch when the copter is leveling in Stabilize. (Autotune only changes out of stabilize for the half second while it is doing the twitch then switches back to normal stabilized flight). It looks like the twitch request stalled the motor or the esc lost sync and the copter then couldn't recover. It happened so quickly that the copter only rotates 2 degrees before rolling back in the opposite direction.
      This is generally caused by sync issues with your esc. However, I have never seen one quiet like this before.
      I am very sorry to see your crash!!
    • I think you've had some sort of electrical or mechanical failure. The IMU's indicate your copter was upside down at the end and your motors are a mixture of flatlines and redlines. Maybe you lost a prop or a motor? Or something came unplugged? There is also a large voltage drop on the Vcc in the middle of this.
      • If you look at the end yes. It's stuck upside down in a chain link fence flailing around. But towards the middle shortly after going to Alt Hold, you can see where ch8 went high starting Auto Tune, that's the point it went out of control. Not saying it wasn't a physical problem, but the erratic behavior coincided with the beginningof Auto Tune.
        Thanks for the help,
        David
        • If you look at ch1 and ch2 one goes to max and one to min, this starts a little while after autotune has started. Can you check those channels?
  • Yesterday i had some crazy values from accu-voltage and current.
    It was the first flight after update to rc5 (from rc4). I heard this values also from the voice of the GCS (Tower) but the copter-flight was normal (incl. AutoTune), so i ignored it.
    At second flight/accu everything was OK. Also third and fourth.
    The question is now, why does these strange voltage-values not trigger the battery-failsafe? (it is set to 9.9V)
    Greetings from Germany, Marcus
    3702021003?profile=original
    2015-06-06 19-25-12.bin
    https://storage.ning.com/topology/rest/1.0/file/get/3702021021?profile=original
  • Second time it happened since v3.3 and I am not sure if it is v3.3 related of I have an other issue.  All in all, after landing (throttle minimum, altitude 0 - copter on the ground) when I try to disarm the copter (0 throttle,rudder left) two motors spin up causing the copter roll over (crash disarm).
    2015-06-06 16-55-06.zip
      Hi Robert,
      This is interesting. You were in Pos Hold at the time. That is the only mode I didn't have a major hand in designing. Does this happen in any other modes?
      I will chat to Randy about it.
      • I could not find the other log, when it happened first I thought I made a mistake with the sticks.
          Hi Robert,
          Thanks and let us know if you see it again.
  • 3.3 rc5 crashed after a full left roll stick ....  twice....
    here is the log .
    5.BIN
    4.BIN
