Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • I tried rc7 on both quad and hex. initial lift off is nice now, with clean vertical movement with no wandering to the side or jumping around.
          upon landing with throttle to the min it stops motors rotation but really does not seem to disarm the drone, I had to press motor kill switch then and wait a bit for disarm to happen.
          I actually liked that routine better, at least for me it is better with no automatic disarm.
          what was good - upon landing it did not try to do a crazy dance popping up and down then falling on a side  and hitting ground with props that it did before with 3.2 and rc5. it landed smoothly and remained landed, so, not sure what was done there in rc7 but it obviously worked.
        • I tested the day before yesterday for the first time AC3.3rc6 on My T-rex500, basic flight conditions can also, with rc5 was close, but after the automatic landing, did not disarm the master within a certain time, it had not been able to close the signal output ESC, leading after a few seconds, left-leaning body occurs gradually, the main rotor sweep the ground, I was forced to forcibly close the output ESC, which is open only to allow the aircraft to stop stalling switch power output!
          The attached log, please ignore the larger Vibration
          AC3.3rc6 Heli.rar
    • Thanks for the update Randy. How can we know if there are attitude estimation errors?
  • Hi,
    currently i'm running a pixhawk on ac3.2 firmware.
    I'm interested on using this ac 3.3, but it has been rolling from rc1 through rc6 and still on beta version.
    Is it save for me using this ac 3.3 rc6 now? I'm not a newbie but nor an expert as well.
      arga,
      No, -rc6 is not safe it seems so best to at least wait for -rc7.
    Hi Winston,
    I have been looking at your log. Repost your issue then reply with a link and I will chat to you there.
    Winston,
    Sorry about your crash.  This looks like an AC3.2.1 log.. Please remember this is the AC3.3-beta testing thread.  I know it's hard to find support sometimes but it muddies the waters to post this here.
    • I apologize Randy, is that yesterday I was flying with Arducopter 3,3-rc5 and thought I could post the problem here, though I'm sure it was not a firmware problem ..
      Sorry ...
        Winston,
        Nah, I shouldn't be such a stickler especially considering in this case you sacrificed a copter during beta testing. Hopefully Leonard can sort you out, if he needs backup I'll have a look.
