Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thanks for pointing people at the wiki page. I've added a bit more information below the graph on that page saying how the number is calculated and providing a link to the short function in the code that does it.
We're not sure yet how high the vibration levels can be before it starts causing problems with control.
I think if you're not getting clipping the vehicle will be kept under control - i.e. it won't do any rocketing into the sky. It's also likely though that the higher the vibes, the bumpier the alt hold will be.
is it okay to use the autotune values for pitch and roll in arducopter 3.2.1?
which parameter changes the new autotune?
SpeedyHulk,
Yes, the PID gains from AC3.2.1 should work fine on AC3.3. I tested with my IRIS using the standard parameter definition file from 3DR and it flew a-ok.
Good morning ,
sorry for bad english. my Problem is,with 3.2.1 and tbs style Frame i have very aggressive "rate" d and p values on pitch. there a many wobbles at full Speed. i read that with 3.3 i can make autotune less agressive. so i thought, i test 3.3 and use this values on 3.2.1. the reason is, i´m not sure how stable the 3.3 rc´s are. my first test was with rc5 and i had the Problem in Mission planner that baro alt was after arming very strange. sometimes it was minus 15meter. so i didn´t test in the air.
yesterday i flashed the copter with rc7 and this Problem was away. perhaps i have time to test today.
i like arducopter since two years. but on bad days i hate the pid tuning;)
best regards
edit: Change autotune in 3.3 only the "rate" values or something more (for example ATC)?
Randy,
Flew my Y6B last evening just prior to a squall coming through the area. Test was mostly in PosHold and Loiter to evaluate GPS accuracy and RC7. Flight went well at low altitude so I pushed it up to 100-150ft and hovered her in the winds. She preformed quite well. After I landed I downloaded the logs and took a look at the vibrations. Both X/Y and Z were well within limits but I when I zoomed into any particular area, I noticed approx. every second or so a dead zone where date dropped out for a very short period of time then picked up as if nothing happen only to drop out again a second or so later.
Has this been discussed in this blog and if not, what is causing this to happen. I never saw or heard any motor cut outs or irregularities so I think this is in the software side of things.
I will later this evening post a screen capture of this and provide a URL to the log file.
Doug, this could be caused by your Dataflash microSD card not being able to keep up with the data rate. For rc7, the dataflash rate has been increased to 400Hz, so we can gather more data on the EKF performance. You should notice that the log files are also really big now. This is probably just going to be a temporary thing for rc7.
This should be no problem for the flying ability of the system, it's just missing data log data.
The standard microSD cards that come in the Pixhawk can't keep up. If you want to see all the high rate data, you need a better dataflash card. Apparently something with the UHS-1 label should work. But even that seems a bit variable. Some brands work, some don't. I'm using an 8GB Adata UHS-1 card I got for just $7, and it seems to be able to keep up.
Thanks Rob. I will look for a better performing micro-card.
I use the Samsung EVO 8gb microSDHC UHS-1 for bought it for 9 Euro.
It work on Pixhawk and AUAV-X2.
What GPS is it? I have tons of Data drops on m8n units that are set to 5Hz. When I lower to 2Hz they go away.
This is related to vibration testing.
