Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thanks. I'll use those features and probably do it one axis at a time.
@Pedals2Paddles: Yes one axis or combination of axis if your battery can handle long flights..
In mission planner from the complete tree open the autotune tab and set the axis you want as follow:
Autotune Bitmask: 0:Roll,1:Pitch,2:Yaw
VALUE MEANING
7 All
1 Roll Only
2 Pitch Only
4 Yaw Only
3 Roll and Pitch
5 Roll and Yaw
6 Pitch and Yaw
@Edwin Janssen: It is true that you can do multiple axis at a time but only if your battery is able to last the time required for multiple axis. On medium or large multi rotors it is not obvious.
Henri
Hello Dev-Team,
Here a log from my last Autotune with aggr 0.05.
I tuned only the roll-axis
The result from the autotune is not good. The copter is oscillating.
Hi Andre,
The problem is you had your aggr set to 5 not 0.05. This means you were working with 0.2.
let me know how you go with the correct setting.
Sorry for the late reply!!!!!!
I autotuned my s900 the other day with aggr 0.05, and it still oscillated and needed to be manually detuned about 20% before it would fly without shaking. Can the autotune aggr be set below 0.05?
Just reran the autotune with RC8, and it looks to have given me a good set of PIDs on the s900 with aggr 0.05. It looked pretty hairy when the yaw tune started, gave big wobbles on roll, but sorted itself out by the end. Will try on the T960 shortly too.
Thanks for looking into it Leonard. Without a gimbal attached I'm sure the autotuned values from 0.05 would be appropriate, but with the gimbal attached, my big copters (6kg t960 and 7kg s900) always seem to need a manual reduction in the PIDs after autotune to stop shaking. I'll give them a retune with rc8 and see if there's any difference from the tune I got out of rc7.
Hi Glenn,
Currently you can actually set the aggr from 0.05 to 0.2 but I don't encourage going outside the 0.05 to 0.1 range. I could drop the hard minimum to 0.02 so people can experiment. It is hard because I test this on 8 different copters from 600g to 10kg and don't need to go outside of that range.
I am concerned that someone might make it very small by accident and get a very sluggish tune....
I will think on it.
Had a scary moment after landing in PosHold, throttle down and instead of shifting to stabilize mode to disarm I shifted to auto mode again. Had the throttle down and left to disarm but the quad throttled up and did a circle on the ground. I thought it was going to flip over but luckily it didn't.
log
263
264
265
266
267
of 449 Next
