Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
do we know when RC8 will be released?
Randy said Monday on pg 193 that he thought it would be out "Later this week".
Nathaniel ~KD2DEY
"we" don't and I am pretty sure the devs don't either yet.
So, yesterday i make 3 Flights with HDOP 1.6-1.8 thx Randy the Settings SBAS_MODE and MIN_ELEV help me.
So i have a new Failure: Droneshare Mission 2
Tlog
The Altitude Jumps from 0 at arm to 199m this is so strange i flys in 10 meters.
The other Test Fly same Problem
Droneshare Mission 1
Your "Altitude AHRS2" reference has nothing common with pressure altitude coming from Baro and that you should look at.
So I see no failure... maybe a little confusion about the terminology.
Marc
Please can you share the dataflash log about this event?
I haven't found altitude (baro) problem in the tlog, max 10 meters.
Hi Randi and all the devs! After giving my tricopters a long rest I came back to one of my birds and decided to update it from 3.1.5 to 3.2.1 needless to say the eimprovement is apparent, however it seems that there is a new minimum value for Stab Yaw - 3.0 For the tricopters I usually like my Yaw at around 1.2~1.4 and MP doesn't allow me to set it lower than 3.0 through the extended tuning and starts to complain that the number is out if range when I change it in the full parameters list. So will something really bad happen to my tricopter if I set it lower than 3.0? I mean will it cause some sort of mistake in the code like dividing by 0 or out of bound array?
Is a repeatable 'error compass variance' condition pose any issue for a ekf system? May it produce any side effects like non smooth mvement at loiter or circle or will system revert to a stable compass and ignore one with a variance?
Paul,
I think it could lead to the EKF not using the compass so it could be serious. I've heard from Rob as well that he often sees this on his TradHeli but it's not clear if his frame is the issue or if the EKF is being too strict about the compass quality. I suspect it's the latter. If you've got a dataflash log I think we should ask PaulR to have a look and we may need to adjust the EKF's strictness.
if we have an internal and an external (in the GPS unit) compasses, which one is which in the parameters?
I just applied copper foil to the bottom of the AUAV case and same copper foil on top of X8R unit that is right under the FC case and ran compass recalibration, in the same spot where I did it before.
Compass offsets always change a ton after each calibration and it always somewhat puzzled me, how can it be so?
look at prior and post results. Obviously an external compass should not have been affected, as nothing was changed on the drone or wires around it. Yet both compasses show new offsets, with first compass showing major change and second just a bit of it.
So, is it a COMPASS_OFS2_% set of parameters that applies to the GPS based compass?
BTW, even after this foil around FC and X8R it still pops up same compass variance error when I move drone around by hand.
as I fly it a lot in the simple mode I can say it is reliable and does not ever confuse its rotation/location, so compass data quality should be quite adequate but I am not sure which data set it uses.
