Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
But IMU AccX, Y, Z level acceptable (IMHO). So I don't understood why IMU vibes good but VIBE section are bad.
Have tested from rc1 still have the very same experience that position hold is behaving strangely (1) unreasonable rapid roll movements (no wind) after switching from Loiter (2) very bad breaking performance even with max settings (angle/speed of change).
[cannot upload logs due to size]
Robert,
No much has changed in PosHold vs AC3.2.1 but it's certainly possible that it's been broken somehow. Have you tested AC3.2.1's PosHold with the same parameters to see that it performs better? I'd just like to confirm that this is an AC3.3 issue instead of a general PosHold performance issue.
Randy - you might be right, I did not use/test position hold intensively before 3.3 so I am not sure. Due to the nature of problems (copter movements) I assumed it is EKF related but it is assumption only.
Hi all, quick question if I may.
Since upgrading to 3.3rc8 I'm having problems connecting via the radio telemetry port. I no longer get the flashing red LED on the air side half of the pair. I thought the receiver had failed and purchased another one. But this is the same.
I can roll the firmware back to v3.2.1 and everything works fine but as soon as I revert back to 3.3rc8 it refuses to work.
I read this thread daily and don't recall any notes about this so I thought I'd ask.
Any ideas?
regards
Mark
Mark,
I'm going to assume here that you are using telem1 for your radio.
If you connect your telemetry via less than 6 wires, IE, your radio doesn't have or doesn't connect RTS/CTS and if you have BRD_SER1_RTSCTS configured for automatic flow control (2, the default), then you have encountered the bug I reported here: https://github.com/diydrones/ardupilot/issues/2532
This bug was present in the code for older releases, but seemed not to manifest there.
You can work around the bug by setting BRD_SER1_RTSCTS to 0, no flow control. Please let us know if this is your problem.
I submitted a pull request 3 weeks ago which fixes the bug and also vastly reduces the time required to detect the lack of flow control, but so far the developers do not seem to have had time to review and merge the fix.
--Brad
Thanks for the replies gentlemen,
The problem was fixed by Brad's suggestion. Working on 3.2.1 but not on the latest really confused me.
I really appreciate your help.
cheers
Mark
Randy didn't mention it in the release notes, but my PR for this bug was merged and is included in AC3.3rc9 so automatic flow control should be working again now.
--Brad
Randy,
I had suspected this was a 3.3 only bug and Mark's experience seems to confirm that.
I'm guessing some timing changes exposed this latent race condition sometime in the 3.3 rc series. In any case, I'd consider it a regression and perhaps you will want to review this PR prior to the 3.3 release.
https://github.com/diydrones/ardupilot/pull/2556
Thanks,
--Brad
Probably not helpful, but my radio telemetry works fine on rc8.
It's working on telem1 as well as telem2.
Do you have something else connected in parallel with the telemetry radio with an Y cable?
