Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • That's really odd.  I've been mapping with 3.3 since it was released and after fixing the offsets in the geotag window.  But even when the Mission Planner geo tagging wasn't working, Pix would work.  I'm back to MP to geotag as it's more accurate (not really that big of a deal) though.
            • I'm sure it's something I have or am doing wrong,
              • Send a log file to Pix4d, they'll get you going again.  Nothing worse than not being able to work.  There's still a 90 degree kappa angle error when using Pix4d though.  No big deal, again just don't select high precision if you're using 2.0 Pix4d mapper.  Earlier versions don't matter.
      • What are you using to trigger the camera?  Gent led and other ir triggers are problematic at best lol.  I use direct multiport on a relay output, never miss.  If you can't match them up and you're using Pix4d, their geotag function will work.  If your geolocation is off, just don't select high precision.  Won't effect your precision, it just takes longer to process.
    • Based on the numbers you list, there are 16 fewer images than triggers.  This seems consistent with the behavior you have seen previously.
      GlennM, replied over on your other thread but in short, it's probably that the SD card can't keep up.  Try reducing the logging or replacing the card.
  • Hi Devs! Is it now possible to transfer telemetry data to an graupner HOTT system?
    • There is  a patch for HoTT protocol support by Adam Majerczyk
      I'm using HoTT for two years with APM and with PX.
      Also there are some MAVLink2HoTT translators. I made one of them. It's firmware for Arduino micro etc. You can easily find it within this group.
    • I bet if you sent Randy and a couple of the developers a Hott enabled Tx, you would find it supported by the end of the week!
