Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Is 3.3 out?
    Checked in MP for beta FW and I got "APM:Copter V3.3 Quad"?
    Or a bug in MP.
  • This reply was deleted.
    • Hi Arpan
      Welcome to DIY drones !   I see you posted a message relating to Version 3.2.1 ..Please can you post this message on the correct place for 3.2.1 support ..here at http://diydrones.com/profiles/blogs/arducopter-3-2-1-released.
       This place is for 3.3 version running with Pixhawk 32 bit controller.
      Hi Kurt,
      I hope to have one shot support in the next release.
      As for the future of Acro, I am the lead control dev for the arducopter project and my personal interest is FPV racing and acro. So there is no chance we will drop acro!
      I do most of my control testing using my high powered racing quad and before that a QAV250. Arducopter flies these small copters very well but it does require some adjustments from the defaults. My blog post goes into detail.
      http://diydrones.com/profiles/blogs/fpv-racing-using-arducopter
      • I had almost given up on flying mini quads with APM code and was starting to consider the other options cleanflight and openpilot. But after reading your "fpv racing using apm" post a few weeks ago, I have tweaked the settings you mention in your write-up and ... bloody hell... what a difference. This turned my mini into a really agile racer! I have since built another mini now with pixhawk instead of apm board. I am really really impressed. Thank you for your great work! Looking forward to future acro development.
      • Hi Leonard, I had a look at the PR's on clearflight for dterm filtering and interrupt based control loops. They look pretty cool - I was wondering what your opinion was about the applicability of these to APM? I'm guessing that the involvment of nuttx and friends makes close to the metal control more difficult?
          Hi Andy,
          The D term filtering is something we have been doing from the very beginning (when we put the D term in) and my reading of their thread suggests they may have used our numbers as a starting point. It was only recently I made it a settable variable to ensure we could get the most out of the faster quads while ensuring the larger quads could be kept low on noise.
          The reasoning behind the interrupt based control loops is also something we have been aware of and using for a long time however the process of squeezing the most out of the APM has meant we had to make some compromises there. I have been talking to the other devs about restructuring the way the fastest loops are run to keep them closely synchronized with the reading of the rate gyros and outputting to the esc's. Our setup is a little more complicated because we have multiple sensors running at different rates and therefore we need to be careful how we do it.
          There is a lot of great engineering going on in all the flight controllers and it is exciting to see everybody try to get the most out of the technology!!!
          Thanks for bringing this up, it is always good to have this stuff highlighted in case there is something we are missing!!!!
          Hi Kurt,
          Yeh, the APM 2.6 is simply not fast enough to get good performance out of the smaller copters. I am not surprised you had trouble. The pixhawk has changed all that though!!!
          Glad you liked the news!
          • I've had great luck with the mini apms v3.1 on 250's. Just finished building my 4th one and they fly really well all in all. I am thinking though of swapping this one out for a hawk lite before I sell it though just to see how different it flies.
              Hi Craig,
              I would be very interested to hear how they compare!!!
              Please give me feedback on my FPV racer blog page if you don't mind.
              Thanks!!!!
        • Hey Kurt,
          I got my QAV250 tuned on 3.3rc11 with Leonard's help and it flies really well! Before autotune it was really unstable so I recommend that you try this and see how you get on.
