Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • So did some experimentation with batteries on my QAV250 because of that youtube clip. Turns out the wire end of a LiPo has much more interference than the blunt end, even if the wires are close together or twisted together (I know the wires cause interference but it's interesting that its so pronounced). If I mount the battery with the wires near the compass but folded back I get 80% interference, if I turn the battery end over end I get 20% interference, even though the battery itself is in the same position. I have subsequently resoldered all the XT60's on my small lipos so that they have short tails so that I can mount them with the wires pointing out the end of the quad.
    I haven't flown yet, but I'm pretty hopeful!
  • I'm not sure if this is the place to post a request for the next release, but it would've been nice to add a rc overide for the mount when dealing with ROI. Sometimes Gmap overlay is way off, in my area is like 5-10 meters offset, many times doing auto missions with ROI I have to move the ROI around in MP until I find the right spot.( I'm using ST32 gimbal, all angles match in the gimbal controller and FMU). Also if one is to change his/her mind in the middle of a mission and wants to take manual control of the gimbal is kind of impossible until the mission finishes. A workaround I've found, is to briefly change modes back and forth. It would've been even cooler if we can set ROI in flight, pointing a camera at a desired target and set ROI with a switch, kind of like save WP option. To whom may be interested, regarding my crash posted here few pages back, I have found no mechanical issues, I've flown it since then with 3.2, I mean realy beating the hell out of it and it performed flawlessly, in the process I also recovered the lost plane after almost a week, intact, only with a puffed 5A lipo. Speaking of finding the needle in the haystack, I have covered 2 acre of sugarcane field until I spot it. Just for fun I'll upload just the frame where I have found it after examining almost 1 hour of footage. I'll make a story about this, it was such an adventure. The sugarcane is about 3.5-4 m tall, I have flown at 20m with a 90 degree fov lens. The plane it white 1.5m span, see if you can spot it. This is the only frame where is the most visible.
    • Took a few seconds ....... about 20% right of the left margin and about 25% down?
      I can imagine you going nuts looking at hours of that sugar cane!
      One went on a full sized sailplane retrieve where the guy had landed in a sunflower crop field. The sunflowers were ripe so the field so looked black like a nice inviting ploughed field from above. It was only when he was committed that the pilot saw it was a tall crop ( also about 2.5 to 3m tall )
      Plonked it in and sank to ground level. We drove around the perimeter of that particular field ( several hundred acres ) more than once. Aircraft was only 50m in from a boundary but totally invisible. :) We found the pilot at a farmhouse eventually. He'd tied a jacket to the fence near the aircraft to mark the area and even then you could walk 15m away and not see a 15m wingspan bright white full sized aircraft!
      We took several buckets of dry sunflower seeds out of the fuselage when we got back to the airfield!
      This was all 40 years ago, if we'd had a UAV it would have been a lot quicker to find it! :)
  • Hi, would anyone be able to provide some assistance here?
    Built my second machine and I haven't gotten it quite right as yet. Its been having and inconsistent yaw issue, where it yaws uncontrollably. Sometimes it responds to input, sometimes not. One day itl be fine, the next, not. I've torn everything down and tested almost everything i can think of. Today i accidentally armed and took off in loiter, but the yaw issue was still there, surprisingly it seemed like loiter kept in from spinning off into a random direction.  I can list each component if necessary, Attached are two logs,
    7.bin is where it flew mostly fine.
    15.bin is the most recent where the uncontrollable yaw is happening again
    https://www.dropbox.com/s/kpsc58i3mtecrn7/15.BIN?dl=0
    https://www.dropbox.com/s/weiz8z466ys7sok/7.BIN?dl=0
    Dropbox - Link not found
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
  • not sure I understand this parameter setting for EKF_FALLBACK, how can EKF fallback to itself? or am I misunderstanding (am sure I am!)
    whats the basis for using either option? would love to hear from one of the devs
      IvanR,
      This parameter is ignored in Copter but is used in Plane.  We could probably hide it but in any case, in Plane they allow the user to choose whether to use DCM or EKF but for Copter that's never a good choice because DCM can't do the position accuracy we need for RTL, Loiter, etc.  There is one exception in that Copter will fall back to DCM if the EKF has NaNs appear within it.  This should never happen because we should have the necessary checks in the code to stop it from happening.. but the fall back is there just in case.
    I made a mistake during the release process yesterday and TradHeli has accidentally been upgrade to Copter-3.3.  The testing for TradHeli isn't complete so we will revert it to Copter-3.2.1 asap.  Any TradHeli users out there reading this should not upgrade to Copter-3.3.
    Multicopter users should not be alarmed, this is a TradHeli specific warning.
DIY Robocars via Twitter
Saturday
Saturday
Jun 16
Jun 13
Jun 13
Jun 13
Jun 7
Jun 7
May 28
May 15
May 14
May 13
May 13
May 11
May 8
May 8
