Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hello, I just want to report that today I finally was able to fly, the weather wasn't allowing.
3.3.2 flew awesome! No issues. Congrats to this great team!
Relationships between PID settings - Vibration - INS_ACCEL_FILTER settings?
Can anyone explain these relationships? I found on my FW-450 with Pixhawk (3.3.2 fw) / RCTimer MT2610 920kv, BLHeli 30A, 1045 prop at default I_ACC_FLtr = 20 and using 3DR foam for FC mounting I have vibration (IMU_AccelZ plot) between -11 to -9 (+/-1g) should be good (at least it is 5 times smaller than recommended) but in AltHold it is still jumps up and down a bit.
On newly assembled nighthawk clone (320 base with APM mini, M8N GPS, EMax MT2208 II, BLHeli-20A) FC set on harder foam and this FC is small and light so not much vibration dampening. At filter INS_MPU6K_FILTER set for 20 vibration between -15 and -5 (AccelZ) with filter set to 15 - vib. -12 to -7 but the flight behavior (oscillations) as if I am tuning PID, very similar to a bit higher values of rate P.
Is it possible to set lower values of INS filter (to get lower vibration) and compensate oscillations with PID tuning?
APM is notorius for vibration sensitivity, I could not get it to PosHold almost at all, Pixhawk is a bit better, but only with very soft foam pad - may be it could be alleviated by FILTER - PID conbination?
Any Ideas? Explanations?
I'm have a bit of an issue on my 960 hex with inconsistent compasses. It shows up on pre-arm quite often and requires several compass calibrations to settle in regardless of where it is or if it armed previously at that location. Compass offsets are always different every time I calibrate and below 400. The setup is the same as my 550 quad and my 690 hex that have remained set unless I change hardware. The only difference is that I have doubled the distance of external compass to airframe. This thing has 3 to 4 times the power draw as the little guys so I expected it to be more sensitive but I'm getting tired of doing the calibration dance with such a large, heavy partner. It always flies perfectly in loiter or position hold once armed. To be clear, when looking at compass offsets on the parameter list, is compass 2 the external and "compass" the internal? And would COMPASS_LEARN be something to try?
Pixhawk, Zubax GNSS module
Thanks RB
Look at the compass?_dev_id. My pixhawk have the internal ID = 131594. My external ID = 73225 , it is a genuine 3dr ublox gps. In my conf , the compass_dev_id is the external and compass 2 is the internal. You shoud set the compass_primary to wherever your external compass is at. Try that and see if helps.
I have never used compass_learn...
Cheers, RB
Hey guys, I have a Y6 running 3.3.2 and today I decided to test its max carrying capacity, by adding about 3kg payload bringing total weight to about 8kg, it was flying fine with 6-7kg I designed it to carry, however at 8kg It constantly wanted to rotate CCW. I've checked RCOut logs and it looks like motors 2,4,6 were at 1700, while motors 1,3,5 were at 1400. Does it suggest that I should be runni g bigger props at motors 2,4,6?
Hi Artem,
This is actually a really interesting question. You need to increase the drag for a given RPM. Increasing the diameter of 2, 4, and 6 may do this. But with the interaction of the upper and lower props it is very hard to say.
So a long story short, I don't know but I am really interested to hear what happens when you try different things. You can increase the pitch on the lower props, you can try increased diameter on upper or lower props, or you can increase the CV on the lower motors.
Let us know how you go!!!
Thanks leonardt, I've ordered a few 1655 cf props from china, will test with both - upper and lower. Btw, did you mean KV (CV)?
The scarse info on coax setups I was able to find suggests that lower props should have larger diameter. Inceasing the pitch is usually not enough.
Artem,
I started a discussion on RCG about coaxial efficiency per eCalc authors. I tried various prop combinations and found the most stable to date was using Xoar 15x5 top and Xoar 14x7 bottom, tried different timings as well which did make a difference.
As you can see, I had the same problem as you:
Below is with Xoar 15x5 top and Xoar 14x7 bottom. I bought some 14x8 but broke one of the blades and never reordered. I now have genuine T-Motor 15x5.5 top/bottom and it is not as stable; haven't flown it for quite some time but want to put the Xoar 14x7/14x8 on the bottom. One thing I'll say is the cheap props flex way too much and cause oscillations.
I also believe the axial distance between the props changes things as well, and with much confidence conclude no two Y6's are the same (had three of them), nor does one size fit all. I'd like to try BLHeli firmware on the HW Xrotor ESC's on this copter.
Xoar 15x5 top Xoar 14x7 bottom. Very stable and reduced VRS substantially.
Link to RCG discussion:
http://www.rcgroups.com/forums/showthread.php?t=2365475
Link to eCalc essay:
http://ecalc.ch/calcinclude/help/xcoptercalchelp.htm#hints
Hi Artem,
Sorry, Typo. KV
54
55
56
57
58
of 449 Next
